This XenForo 2.1 addon adds extra info to the entries in the Approval Queue to help make approval decisions easier.
The approval queue was redesigned for XF2.1 - this addon adds back some additional information.
Before :
After :
Specifically, the following information is shown :
There is also an admin option to reverse the default sort order of the Approval Queue.
... finally User Agent data can be automatically pruned for approved users after a specified number of days.
Télécharger V3.3.1 :
Version 3.4.0 bugfixes and XF 2.3 compatibility : Changes in this release :
Version 3.5.0 with Cloudflare location support :
This version adds support for showing Cloudflare geo-location data for sites running Cloudflare. To enable the display of Cloudflare location data, you must turn on Managed Transforms in your Cloudflare admin console. Go to
Télécharger V3.5.0 :
Version 3.5.1 bugfix for faulty upgrade :
- Fixes a critical upgrade bug (doesn't apply to new installs), where certain columns didn't get created.
Télécharger V3.5.1 :
Version 3.5.2 bugfix - missing admin permissions :
- Minor bugfix to explicitly enforce admin permissions on admincp tools.
Télécharger V3.5.2 :
Before :
After :
- Username
- Date joined
- Date of last activity
- Registration IP
- Location
- Time Zone
- User Agent
- Email requires "Bypass user privacy"
- IP address requires "View IP addresses"
- User Agent requires the custom "View User Agents" permission added by this addon
- update permission phrase to make it clear where the permission comes from
- rename user agent table from xf_user_agent to xf_aqp_user_agent to comply with resource standards
- bugfix - gracefully handle case where user agent doesn't exist for user
- fix approval_item_user template modification for compatibility with XF 2.3
Rules > Transform Rules > Managed Transforms and enable Add visitor location headers.Télécharger V3.5.0 :
3.5.3 (2025-12-11)
- run enqueuePostUpgradeCleanUp during upgrades if we're running XF2.3+3.6.0 (2026-09-20)
- now requires XenForo 2.2.0 or later
- fixed: Cloudflare continent information was never recorded, because the
CF-IPContinentheader was misspelled internally — it is now recorded, and shown on the Cloudflare location test page under Tools > Checks and Tests - fixed: the user agent clean up option's on/off setting is now honoured — switching it off did not previously stop the scheduled clean up from running
- the
viewUserAgentspermission is nowhampelAqpViewUserAgents, so that it cannot clash with a permission of the same name from another add-on — existing permission settings are migrated automatically during the upgrade
3.6.1 (2026-09-22)
the Cloudflare location in the Approval Queue now ends with the continent — for example Sydney, NSW, Australia (Oceania) — for users who registered on 3.6.0 or later, which is when continent began to be recordedVersion 3.6.2 (2026-10-04)
- fixed: registration failed for any client that sent no
User-Agentheader — browsers always send one, so ordinary sign-ups were unaffected, but a scripted or API registration was refused - fixed: clearing the Delete User Agent data after box no longer deletes every approved user's recorded data on the next scheduled clean up
Version 3.6.3 (2026-10-10)
- now requires PHP 7.4 or later — above the PHP 7.0 that XenForo 2.2 itself requires, and needed by the new command line checks below. XenForo 2.3 already requires PHP 7.2, so this affects only a XenForo 2.2 forum still running PHP 7.3 or older
- new: two command line checks.
approval-queue-plus:configprints what the Approval Queue is set up to show and what has been recorded; approval-queue-plus:validate checks that it all works — that the queue's template modifications still apply, that the Cloudflare header map still produces a location, that the View User Agents permission is present, and that the scheduled clean up will run when it says it will. Neither command writes, deletes or sends anything, so both are safe to run on a live forum approval-queue-plus:validateexits 1 when a check failed and 0 otherwise, and--strictexits 2 for warnings alone, so a monitoring script can watch a forum's configurationapproval-queue-plus:validatereports a clean up that can never run: switching it on while leaving Delete User Agent data after empty makes the scheduled prune decline every time, which is safe but silent- the add-on now tells the Admin API add-on that none of its settings are credentials, so they can be reported rather than withheld
