This XenForo 2.1 addon adds extra info to the entries in the Approval Queue to help make approval decisions easier.
The approval queue was redesigned for XF2.1 - this addon adds back some additional information.
Before :
After :
Specifically, the following information is shown :
There is also an admin option to reverse the default sort order of the Approval Queue.
... finally User Agent data can be automatically pruned for approved users after a specified number of days.
Télécharger V3.3.1 :
Version 3.4.0 bugfixes and XF 2.3 compatibility : Changes in this release :
Version 3.5.0 with Cloudflare location support :
This version adds support for showing Cloudflare geo-location data for sites running Cloudflare. To enable the display of Cloudflare location data, you must turn on Managed Transforms in your Cloudflare admin console. Go to
Télécharger V3.5.0 :
Version 3.5.1 bugfix for faulty upgrade :
- Fixes a critical upgrade bug (doesn't apply to new installs), where certain columns didn't get created.
Télécharger V3.5.1 :
Version 3.5.2 bugfix - missing admin permissions :
- Minor bugfix to explicitly enforce admin permissions on admincp tools.
Télécharger V3.5.2 :
Before :
After :
- Username
- Date joined
- Date of last activity
- Registration IP
- Location
- Time Zone
- User Agent
- Email requires "Bypass user privacy"
- IP address requires "View IP addresses"
- User Agent requires the custom "View User Agents" permission added by this addon
- update permission phrase to make it clear where the permission comes from
- rename user agent table from xf_user_agent to xf_aqp_user_agent to comply with resource standards
- bugfix - gracefully handle case where user agent doesn't exist for user
- fix approval_item_user template modification for compatibility with XF 2.3
Rules > Transform Rules > Managed Transforms and enable Add visitor location headers.Télécharger V3.5.0 :
3.5.3 (2025-12-11)
- run enqueuePostUpgradeCleanUp during upgrades if we're running XF2.3+3.6.0 (2026-09-20)
- now requires XenForo 2.2.0 or later
- fixed: Cloudflare continent information was never recorded, because the
CF-IPContinentheader was misspelled internally — it is now recorded, and shown on the Cloudflare location test page under Tools > Checks and Tests - fixed: the user agent clean up option's on/off setting is now honoured — switching it off did not previously stop the scheduled clean up from running
- the
viewUserAgentspermission is nowhampelAqpViewUserAgents, so that it cannot clash with a permission of the same name from another add-on — existing permission settings are migrated automatically during the upgrade
3.6.1 (2026-09-22)
the Cloudflare location in the Approval Queue now ends with the continent — for example Sydney, NSW, Australia (Oceania) — for users who registered on 3.6.0 or later, which is when continent began to be recordedVersion 3.6.2 (2026-10-04)
- fixed: registration failed for any client that sent no
User-Agentheader — browsers always send one, so ordinary sign-ups were unaffected, but a scripted or API registration was refused - fixed: clearing the Delete User Agent data after box no longer deletes every approved user's recorded data on the next scheduled clean up
