[Ap Yazılım] Scroll Buttons 1.0.0
XF 2.3 [Ap Yazılım] Scroll Buttons 1.0.0
Titre du sujet Titre du sujet [Ap Yazılım] Scroll Buttons 1.0.0
Affichages Affichages 6
[Ap Yazılım] Scroll Buttons is a powerful interface add-on coded with modern web trends that elevates the User Experience (UX) of your XenForo forum beyond standards to a premium level. Thanks to advanced CSS and smart mathematical JS calculations, it presents a flawless, dynamic, and visual feast to your users as they scroll through the page. Moreover, it works 100% harmoniously with your theme and strictly contains no hardcoded, incompatible colors.
🌟 Key Features
🎨 4 Different Ultra-Modern Design StylesForget ordinary "Scroll to Top" buttons! 4 premium designs you can switch between with a single click from the admin panel:
  • Thin Ring Bar: As the page scrolls, the up button fills gracefully to the right, and the down button symmetrically fills to the left.
  • Sonar Pulse: Soft and elegant frequency waves radiating outward around the button like a heartbeat.
  • Cyber Frame: A modern, sharp-edged, cyberpunk-inspired design with a sliding light animation.
  • Holographic: Flawless 3D depth perception and light reflections radiating from the absolute center.
⚙️ Absolute Color Discipline (Zero Hardcoded Colors) The add-on does not use hardcoded black (#000), white (#fff), or random transparent codes. All shadows, fills, borders, and glows are powered only by the 4 theme colors you define (Main Color, Secondary Color, Effect Color, Icon Color). It seamlessly integrates perfectly regardless of which theme you use.
🧠 Smart Scroll Memory Regardless of the XF theme you use, its smart JS infrastructure calculates the total height of the page flawlessly. The progress rings will be exactly 100% full right when you reach the absolute bottom of the page.
🛠️ Managing Designs is Incredibly Easy You don't need to dig into the code to manage all this visual feast and design choices. Control everything from a single menu:👉 Admin >> Appearance >> Style properties >> [Ap Yazılım] Scroll Buttons
💡 Why [Ap Yazılım] Scroll Buttons?
  • Offers your users a modern, elegant, and memorable forum experience.
  • Designs feature symmetric animations (opposite direction filling).
  • Uses an ultra-lightweight LESS and JS infrastructure instead of bloated code.
  • Works seamlessly with the native interface, staying 100% true to XenForo standards.
  • Allows you to fully create your own custom color palette.
