AndyB MaxMind updater 1.2
XF 2.3 AndyB MaxMind updater 1.2
Titre du sujet Titre du sujet AndyB MaxMind updater 1.2
Affichages Affichages 25
Updates MaxMind GeoIp2 database.
This add-on will automatically download the GeoIp2 database to your server every day so you will always have the latest version.
Setup step 1 :
Follow the instructions from this link to get your Maxmind license key:
https://www.xf2addons.com/threads/how-to-get-your-maxmind-license-key.1644/
Setup step 2 :
Go to the options page and enter your License key and Destination path.
Setup step 3 :
This add-on requires the Archive_Tar PHP extension. Most servers already have this installed, but if yours does not, follow the instructions here:
https://www.xf2addons.com/threads/how-to-install-the-archive_tar-php-extension.1641/
Questions and answers :
Q: Do I have to create the /home/username/maxmind directory?
A: No. The directory will be created for you the first time you run the cron entry.
Q: What time does the Cron entry run?
A: At midnight every day UTC time.
Q: I'm on XenForo Cloud, what Destination path should I use?
A: Enter the following: internal_data/local/maxmind
MaxMind updater v1.1 changes : Now supports XenForo Cloud.
Télécharger V1.1 :
MaxMind updater v1.2 changes : Improved error reporting.
Télécharger V1.2 :
