Displays a block containing featured media.
This add-on will display a block of media items and is normally displayed in the forum list. Each featured media item can be clicked and the media item will be displayed in the media gallery. Featured media items are randomly selected and updated every 5 minutes.
(Example of Featured media) :
Typically you will set 'Yes' for the following two user groups:
Registered
Unregistered /Unconfirmed
Directory preparation :
Create a directory in the data folder called featured_media and set permissions to 0755.
Creating the widget :
Q: How do I change the "Featured media" title?
A: Edit the featuredmedia_featured_media phrase.
Featured media v1.1 changes : Create a directory in the data directory called featured_media.
Télécharger V1.1 :
Featured media v1.2 changes : Fixed issue with image selection condition.
Télécharger V1.2 :
Featured media v1.3 changes : Updated PHP code and options page.
Télécharger V1.3 :
- In responsive mode featured media are reduced in quantity and size.
- Cron entry will rotate images every 5 minutes.
- All phrases start with featuredmedia_ for your convenience.
Registered
- Admin Control Panel -> Appearance -> Widgets
- Widget definition = Featured media
- Widget key = featured_media
- Title = (leave blank)
- Display in positions = Forum list: Above nodes
- Click Save.
Télécharger V1.1 :
Télécharger V1.2 :
Télécharger V1.3 :
