AndyB Featured images 3.0
XF 2.0 / 2.1 / 2.2 / 2.3 AndyB Featured images 3.0
Titre du sujet Titre du sujet AndyB Featured images 3.0
Réponses Réponses 66
Affichages Affichages 4 695
Réaction Réaction 7
Affiche un bloc contenant les images en vedette.
Les images présentées afficheront trois petites images dans votre liste de forums. Les images sont des pièces jointes que vos membres ont postées.
Les images sont mises à jour toutes les 5 minutes. Les images lorsque vous cliquez dessus afficheront le message dans lequel la pièce jointe a été publiée.
1062
1064
Features:
  • In responsive mode images are reduced in size.
  • Images can be selected from any forum.
  • Cron entry will rotate images every 5 minutes.
  • All phrases start with featuredimages_ for your convenience.
Requirements :
Requires ImageMagick.
To check if your server has ImageMagick, do the following:
Admin CP -> Options -> Attachments -> Default image processor
You should be able to select "ImageMagick PECL extension". If you cannot select this, you will need to contact your web host provider and ask them to install ImageMagick with PECL.
Installation :
  1. Download Andy-FeaturedImages-1.0.zip and unzip it.
  2. Copy the src/addons/Andy/FeaturedImages directory to your server.
Directory preparation :
Create a directory in your web root called /misc/ and set permissions to 0755.
Example :
https://www.domain.com/misc/
Creating the widget :
  1. Admin Control Panel -> Appearance -> Widgets
  2. Widget definition = Featured images
  3. Widget key = featured_images
  4. Title = (leave blank)
  5. Display in positions = Forum list: Above nodes
  6. Click Save.
Featured images v1.1 changes :
No longer dependent of a specific image handler. File system operations now using XenForo file functions.
Télécharger V1.1 :
Featured images v1.2 changes :
Added 'Limit wide' and 'Limit narrow' to options page.
Télécharger V1.2 :
Featured images v1.3 changes :
Improved reporting if attachment is corrupt.
Télécharger V1.3 :
Featured images v1.4 changes :
Added height attribute to img tag.
Télécharger V.1.4 :
Featured images v1.5 changes :
Fixed issue where on occasion a featured image would show full size.
Télécharger V1.5 :
Featured images v1.6 changes :
Added code to identify which attachment is corrupt.
Télécharger V1.6 :
Featured images v1.7 changes :
Improved options page descriptions.
Télécharger V1.7 :
Featured images v1.8 changes :
Fixed issue with HTML validation.
Télécharger V1.8 :
Featured images v1.9 changes : Now supports Server based trigger.
Télécharger V1.9 :
Featured images v2.0 changes : The options page has two changes. If upgrading please remove trailing slash from Image link and Image path settings.
Télécharger V2.0 :
Featured images v2.1 changes : Updated andy_featured_images.less template.
Télécharger V2.1 :
Featured images v2.2 changes : Updated abstracted file system code.
Télécharger V2.2 :
Featured images v2.3 changes : Fixed issue with image selection condition.
Télécharger V2.3 :
Featured images v2.4 changes : Improved error handling code.
Télécharger V2.4 :
Featured images v2.5 changes :
Now compatible with XenForo Cloud. If upgrading from previous version, please create a new directory /data/files/featured_images using File manager, also the Options page Image URL field needs to be updated.
Télécharger V2.5 :
Featured images v2.6 changes : Added Log errors to options page.
Télécharger V2.6 :
Featured images v2.7 changes : Featured images are now square.
Télécharger V2.7 :
Featured images v2.8 changes : Now supports WebP attachments.
Télécharger V2.8 :
Featured images v2.9 changes : Now supports Retina and High-Res displays.
Télécharger V2.9 :
Featured images v3.0 changes : Updated error handling.
Télécharger V3.0 :
J'ai passé toutes les étapes et je me retrouve avec ca :
j'ai fait les réglages comme ca :
Quelqu'un aurait une idée que ce qui cloche par hasard ?
Non je n'ai pas plus d'option :(
2108
J'ai même envoyer les images dans le repertoire "misc" via la ftp...Rien :(
et c'est indispensable pour faire fonctionner l'add on featured images ?
Vous devriez pouvoir sélectionner "Extension PECL ImageMagick". Si vous ne pouvez pas sélectionner cette option, vous devrez contacter votre fournisseur d'hébergement Web et lui demander d'installer ImageMagick avec PECL.
2244
