Sends email to staff about classified thread being created from suspicious IP address.
This add-on is designed for very active forums where thieves log in as a user by means of cracking an insecure password. The thief will then post a new ad in a classified area on a deal too good to be true and ask for up front payment which is insecure. This add-on can help identify such a scam and will help protect your members.
(Example of email sent to staff) :
All phrases start with classifiedlocationcheck_ for your convenience.
Questions and answers :
Q: What triggers an email to be sent ?
A: If the current posting location is from another country from the normal posting location.
Classified location check v1.1 changes : Fixed issue with empty region.
Télécharger V1.1 :
Classified location check v1.2 changes : Fixed issue when country not found in lookup.
Télécharger V1.2 :
Classified location check v1.3 changes : Updated PHP code to fix issue with false positives.
Télécharger V1.3 :
Classified location check v1.4 changes : Compatible XF 2.x versions: 2.3
Télécharger V1.4 :
Classified location check v1.5 changes : Added GeoIp2 support.
Télécharger V1.5 :
Classified location check v1.6 changes : Updated Options page descriptions.
Télécharger V1.6 :
Classified location check v1.7 changes : Now using Composer method. GeoIp2 library is now included in the add-on.
Télécharger V1.7 :
Classified location check v1.8 changes : Updated email format.
Télécharger V1.8 :
Télécharger V1.1 :
Télécharger V1.2 :
Télécharger V1.3 :
Télécharger V1.4 :
Télécharger V1.5 :
Télécharger V1.6 :
Télécharger V1.7 :
Télécharger V1.8 :
