AndyB Block country 2.2
XF 2.3 AndyB Block country 2.2
Titre du sujet Titre du sujet AndyB Block country 2.2
Réponses Réponses 10
Affichages Affichages 168
Blocks access to specified countries.
When a visitor from a blocked country clicks the Contact us, Log in, Register or thread link, they are shown an error message.
(Example of error message) :
(Example of Block country link) :
(Example of Block country page) :
  • All phrases start with blockcountry_ for your convenience.
Setup :
This add-on requires using the GeoIp2 library. Here is a link which explains how to install the GeoIp2 library.
https://www.xf2addons.com/threads/how-to-install-the-geoip2-library.1132/
Go to options page and enter the country codes you want to block. Or if you prefer you can enter the country codes which you allow. Add your GeoIp2 paths.
Viewing which countries were blocked :
Click the Block country link in the visitor menu. Must be an admin to see this link.
Database changes :
A table called andy_block_country is created in your database.
Block country v1.1 changes : Fixed null condition error.
Télécharger V1.1 :
Block country v1.2 changes : Updated options page descriptions.
Télécharger V1.2 :
Block country v1.3 changes : Fixed null condition error.
Télécharger V1.3 :
Block country v1.4 changes : Now blocks countries where GeoIp2 comes up empty.
Télécharger V1.4 :
Block country v1.5 changes : Updated Options page descriptions.
Télécharger V1.5 :
Block country v1.6 changes : Now using Composer method. GeoIp2 library is now included in the add-on.
Block country v1.7 changes : Updated phrases.
Block country v1.8 changes : Fixed error message.
Block country v1.9 changes : Added Days to options page.
Télécharger V1.9 :
Block country v2.0 changes : Updated Options page.
Télécharger V2.0 :
Block country v2.1 changes : Fixed issue with variable name.
Télécharger V2.1 :
Block country v2.2 changes : Changed logic if IP not found.
Télécharger V2.2 :
