Ask Gemini a question directly in XenForo.
When viewing a thread, use Gemini to help create a very informative reply.
(Example of Ask Gemini link) :
(Example of Ask Gemini question page) :
(Example of Ask Gemini response page) :
All phrases start with askgemini_ for your convenience.
Setup step 1 :
Go to Google AI studio and click the Get API link.
https://aistudio.google.com/
Once you get your API key, you will also need to provide a credit card so that Google can charge you for usage. Don't worry it is very inexpensive, average cost per explanation is a small fraction of 1 cent.
Setup step 2 :
In the options page:
Enter the 'API key' from the Gemini API key given to you in step 1.
Setup step 3 :
Set the User group permissions.
How to use :
When viewing a thread, if you would like you create an informative reply using Gemini, do this:
Ask Gemini v1.1 changes : Now using latest Gemini AI model.
Télécharger V1.1 :
Ask Gemini v1.2 changes : Increased timeout to 30 seconds.
Télécharger V1.2 :
Setup step 1 :
Setup step 2 :
Setup step 3 :
How to use :
- Click the More options icon above post #1.
- Click the Ask Gemini link.
- Type your question and click submit.
- Highlight and copy the response page to your clipboard.
- Use back button in browser twice to get back to the thread.
- Paste from clipboard into the quick editor and Save new reply.
Télécharger V1.1 :
Télécharger V1.2 :
