[AL] Filter Framework 1.4.7
XF 2.1 / 2.2 / 2.3 [AL] Filter Framework 1.4.7
Titre du sujet Titre du sujet [AL] Filter Framework 1.4.7
Réponses Réponses 13
Affichages Affichages 717
This package contains shared files used by all our Filter add-ons. The reason for separating this functionality is to make it easier to maintain and to allow for more flexibility in the future.
Version 1.1.0 Latest [AL] Core package compatibility and maintenance changes :
- This version implements support for the latest [AL] Core package and should be installed after upgrading the Core add-on. With this version, we have made general code restructuring which will allow us to easier release new features for individual filter add-ons without affecting the Filter add-ons.
- Upgrade to this version if any add-ons you use require a newer version.
Version 1.2.0: Fix for field order in the filter form
- The release provides a method used by Filter add-ons to sort the fields correctly in the filter form. The version will be required for future releases of Filter add-ons.
Version 1.2.1: Bug-fix: auto-reload is broken when there are no filterable lists in the form
  • The version fixes a bug causing Auto-reload to be broken due to a JavaScript error, when the filter form does not contain any Filterable lists.
  • The update is recommended for all customers using the package.
Version 1.2.4 Bug-fix: PHP Error on newer PHP versions :
- The update fixes an issue reported at RMS Filter by AddonsLab [Paid] It is recommended for all Filter add-ons.
Télécharger V1.2.4 :
Version 1.2.5 PHP error fix for versions 8.x :
- This release contains several fixes reproduced on PHP 8.0+ versions. It is recommended to upgrade for all customers using the package.
Télécharger V1.2.5 :
Version 1.3.0 compatability xenforo 2.3 :
- This release implements the fixes required for our Filter add-ons to be compatabile with XenForo 2.3.x. The package is backward-compatible and can be used to upgrade on 2.2.x boards as well. The support for 2.3.x version for each individual filter add-on will be released soon.
Télécharger V1.3.0 :
Version Bug-fix: XenForo 2.3.x JS event not cancelable :
-This fixes an issue related to our Location field add-on where the filter form reloads when entering the address.
Télécharger V1.3.1 :
Version 1.4.2 Prevent error in case the custom field index is invalid :
- The releases prevents throwing an error when custom field value is for some reason invalid (e.g. a previous field with the same name but different value was saved and now does not have the correct data type).
The release is recommended to upgrade for all filter add-ons.
Télécharger V1.4.2 :
Version 1.4.3 Bug-fix: multiple keyword support fix :
- The release fixes the regression introduced with support for multiple keywords. It is recommended for all customers running Filter add-ons. It is backward compatible with XenForo 2.2.x
Télécharger V1.4.3 :
Version 1.4.6 Feature : Filterable Lists with AJAX-powered dropdowns, infinite scroll, and new developer events​
This update brings the all-new Filterable Lists feature, a set of new developer events for deeper integration, significant UX improvements to the tag/select dropdowns, and full XenForo 2.1 compatibility. It is recommended for all customers running Filter add-ons and is fully backward compatible.
New Features
Filterable Lists support for XenForo 2.3
Fields can now be rendered as searchable, AJAX-powered dropdowns (via Select2 / Tagify on XenForo 2.3) instead of loading every option at once. This drastically reduces page weight and load times for content types with hundreds or thousands of options.
Numeric Field Support
Numeric custom fields can now be used as filters.
Location Field Support
A new event allows add-ons to integrate location-based fields with the framework.
New Elasticsearch DSL Logging
When an Elasticsearch query fails, the full DSL query and exception message are now logged at error level, making it much easier to diagnose ES issues.
New Developer Events
Four new code events give add-on developers fine-grained control over filtering behavior:
  • filter_framework_enable_filterable_lists — Enable filterable lists per field and specify the API endpoint that supplies the options.
  • filter_framework_filter_active_choices — Reduce the loaded choices to active ones only (recommended when Filterable Lists are enabled).
  • filter_framework_display_formatter_active_filters — Customize how a field is rendered in the Active Filters area (template, phrase, params, label visibility).
  • filter_framework_format_field_for_display — Override the default display formatting of any field value.
Bug Fixes & Improvements
  • Fixed the "match any / match all" option container disappearing in certain configurations.
  • Resolved XenForo 2.1 compatibility issues across templates and JS.
  • Removed a class-extension hack for a cleaner, more maintainable integration.
Compatibility
Fully backward compatible with existing Filter add-ons and configurations. No configuration changes are required to upgrade — Filterable Lists and the new events are opt-in via add-on listeners.
Télécharger V1.4.6 :
Version 1.4.7 PHP warning fix for multiple-selection fields :​
- This release is fixing a warning logged in XenForo Server Error Logs when a malformed URL is used related to multiple-select fields.
- The release is recommended to upgrade for all filter add-ons.
Télécharger V1.4.7 :
