AI Rules Moderation 1.0.7
XF 2.1 / 2.2 / 2.3 AI Rules Moderation 1.0.7
Titre du sujet Titre du sujet AI Rules Moderation 1.0.7
Affichages Affichages 3
Conservative AI triage for XenForo approval queues​
AI Rules Moderation helps XenForo forum owners reduce moderation workload by checking new and updated supported public text content against their own plain-language rules.
When content clearly appears to breach those rules, it is moved into XenForo’s built-in approval queue with a moderation reason for staff review. Your moderators remain in control. The add-on does not automatically delete content, ban users, warn users, punish users, publicly mark users, or make final moderation decisions.
The short version​
AreaDetails
Main purposeAI-assisted rule-violation triage for XenForo
Action takenMoves clear likely violations to XenForo’s approval queue
Final decisionAlways made by human moderators
Trial14 days, up to 100 moderation checks
Trial billingPayment method required; billing starts only if not cancelled before trial ends
Paid access$25 USD per year, including 1,000 moderation checks
Additional checksOptional $5 USD top-ups for 500 checks
Auto top-upsDisabled by default; can be enabled with an annual cap
Supported contentPosts, threads / first posts, profile posts, profile post comments
Not supportedPrivate conversations, images, files, media, attachments, old-content bulk scanning
API accessDedicated custom XenForo API scope only: ai_rules_moderation:write
AI processingHosted moderation backend using OpenAI’s API Platform
TrainingCustomer forum content is not used by the service or OpenAI to train AI models
Visible brandingNo end-user branding
RequirementsXenForo 2.1.0+, PHP 7.2.0+, active trial/subscription, outbound HTTPS
Version behaviourXenForo 2.3+ uses native webhooks. XenForo 2.1–2.2 uses an add-on compatibility driver. Scope controls require XenForo 2.3.8+.
What problem it solves​
Some forum moderation problems are not well handled by keyword filters.
AI Rules Moderation was originally built for a stock and crypto community dealing with sophisticated spam, manipulation attempts, self-promotion, personal attacks, and high-emotion discussion during volatile market periods. The problem was not simply “bad words”. The problem was context. Blunt filters missed important issues, created false positives, or treated normal adult disagreement as if it needed action.
This add-on is for forum owners who want faster identification of clear rule-breaking content without handing final moderation authority to AI.
What it does — and does not do​
It does​
CapabilityWhat happens
Checks supported new or edited contentEligible public text content is checked after creation or update
Applies your rulesRules are written by the admin in plain English
Uses XenForo’s normal workflowFlagged content goes to the built-in approval queue
Gives staff a reasonModerators see why the content was flagged
Keeps a local audit trailAdmin CP audit log records moderation callback outcomes
Allows scoped moderation where supportedScope can be narrowed by node, user group, and content type where scope controls are available
Keeps your forum server lightweightAI processing runs through the hosted moderation backend
It does not​
LimitationWhy it matters
Does not automatically delete contentPrevents irreversible AI enforcement
Does not ban, warn, punish, or publicly mark usersStaff remain responsible for enforcement
Does not scan private conversationsAvoids private-message monitoring
Does not scan images, media, files, or attachmentsCurrent scope is text-based supported XenForo content
Does not bulk-scan historical contentIt is event-based, not a retroactive crawler
Does not replace moderatorsIt assists human review rather than making final decisions
Does not use broad XenForo API permissionsUses only the add-on’s custom API scope
How it works​
  1. Install the XenForo add-on using the normal XenForo add-on process.
  2. Open the AI Rules Moderation setup page in the Admin CP.
  3. Enter your forum details and write your moderation rules in plain English.
  4. Choose moderation scope where supported by your XenForo version: nodes, user groups, and content types.
  5. When eligible supported content is created or updated, the add-on sends the moderation event to the hosted moderation backend. On XenForo 2.3+, this uses XenForo’s native webhook system. On XenForo 2.1–2.2, this uses the add-on’s compatibility driver.
  6. The backend checks the author’s submitted message against your rules.
  7. If the content clearly appears to breach your rules, the add-on moves it into XenForo’s approval queue.
  8. Staff review the moderation reason and make the final decision using XenForo’s normal moderation tools.
Built for cautious trials​
AI Rules Moderation is deliberately conservative.
The goal is not to punish users automatically. The goal is to surface clear likely rule violations sooner, inside the moderation workflow your staff already use. If the AI is unsure, the intended behaviour is to avoid acting on borderline cases, ordinary disagreement, or heated discussion that does not clearly breach your written rules.
This matters because automated moderation is risky when it becomes opaque, overconfident, or detached from human context. The Santa Clara Principles emphasise understandable rules, transparency about automated moderation, explainability, and human review. Australian AI governance guidance also stresses accountability, human oversight, monitoring, and avoiding overreliance on automated outputs.
Best suited to​
AI Rules Moderation is best suited to forums where moderation is:
Forum typeWhy it may help
Finance and trading forumsSpam, manipulation, self-promotion, and high-emotion debate can be context-dependent
Gaming communitiesHigh-volume public posting and recurring behavioural rules
Marketplace communitiesPromotions, scams, disputes, and off-platform solicitation
Political discussion forumsHeated debate where context matters
Large hobby and enthusiast forumsRepetitive moderation workload
Fast-moving public discussion communitiesStaff may not see clear issues quickly enough
Communities with detailed rulesPlain-language rules can be applied consistently as a first-pass triage layer
Not suited to​
This is not the right add-on if you need:
RequirementWhy this add-on is not a fit
Automatic bansIt does not ban users
Automatic warningsIt does not warn users
Automatic permanent deletionIt queues content for review instead
Private conversation scanningPrivate conversations are not scanned
Image, file, media, or attachment moderationThose are not currently supported
Bulk scanning of old contentIt only checks eligible new or updated content
AI making final decisionsHuman moderators make the final decision
Moderation scope​
AI Rules Moderation currently supports:
Content typeSupported
PostsYes
Threads / first postsYes
Profile postsYes
Profile post commentsYes
Private conversationsNo
Images / files / media / attachmentsNo
Historical bulk scanningNo
Moderation scope controls can be used to limit checks by node, user group, and supported content type where XenForo’s native scoped webhook dispatch is available. XenForo 2.3.8 or newer is required for those scope controls.
On XenForo 2.1–2.2, the add-on remains installable and functional using its compatibility driver, but scope controls are unavailable and broad supported-content behaviour is retained.
On XenForo 2.3.0 to 2.3.7, the add-on remains installable and functional using native webhooks, but scope controls are unavailable and broad webhook behaviour is retained.
Important scope details​
Scope optionBehaviour
NodesApplies to supported content with a forum/node context, such as posts and thread first posts
Profile postsDo not have a normal forum node context
User groupsIf narrowed from All, selected groups act as a strict allowlist
Multi-group usersA user is checked only if every primary and secondary group they belong to is selected
Trusted groupsLeave a group unselected to skip users who belong to that group
Scoped-out contentDoes not consume credits where scoped dispatch is supported
Older XenForo versionsOn XenForo 2.1–2.2 and XenForo 2.3.0–2.3.7, scope controls are unavailable, so supported content remains broadly eligible for checks
API access and security posture​
The add-on creates a dedicated XenForo API key using only the add-on’s own custom API scope:
It is not a super-user key and it is not a general-purpose XenForo API key. No standard XenForo API scopes are granted for posts, threads, users, attachments, conversations, nodes, alerts, authentication, or general administration.
In practical terms, the API key exists so the hosted moderation backend can return a moderation decision to your XenForo installation, allowing the add-on to move clearly flagged content into the approval queue and record the moderation outcome.
Admins who want to fully revoke callback access can remove, disable, or regenerate the API key from XenForo’s API key area. Uninstalling removes the add-on’s local tables and disables the XenForo-side integration where applicable, but the API key and webhook/integration records are deliberately not silently deleted so the integration artefacts remain visible for transparency and auditability.
Hosted processing and data handling​
AI Rules Moderation requires the hosted moderation backend to function. The hosted service is operated by The Stock Exchange Forum. Payments are handled by Stripe, AI processing may be handled by OpenAI, and security / traffic handling may involve Cloudflare.
For moderation classification, the backend may use:
Data typePurpose
Forum domain / URLIdentify the forum and service account
Forum name and descriptionProvide community context
Saved moderation rulesDefine what should be checked
Supported content type and IDIdentify the submitted content
Author’s submitted messageClassify the actual text
Related forum, thread, or sub-forum context where availableImprove contextual interpretation
Where native scoped webhook dispatch is available, content outside the configured moderation scope is not sent for AI classification. On supported XenForo versions where scope controls are unavailable, supported public text content remains broadly eligible for checking.
Storage and retention summary​
ItemHandling
Payment card detailsHandled by Stripe, not stored by the add-on
Service recordsForum/account, subscription, billing identifiers, credit totals, rules, top-up settings, and operational records may be stored
Successful production checksNot retained as saved hosted service execution history
Errored service runsMay be retained temporarily for troubleshooting and pruned after up to 7 days, subject to normal operational requirements
Short-lived cacheStores forum domain, content ID, and a hash of message content
Permanent archive of forum postsNot intended or created by the hosted moderation service
Local audit trailXenForo audit log may record outcomes and moderation reasons inside your own installation
OpenAI’s own API data controls state that API data is not used to train or improve OpenAI models unless the customer explicitly opts in, and that abuse-monitoring logs may contain customer content and are retained for up to 30 days by default unless longer retention is required by law or necessary to protect services or third parties.
Pricing, credits, and top-ups​
ItemDetails
Trial14 days
Trial checksUp to 100 moderation checks
Payment methodRequired to start the trial
First chargeOnly occurs if the trial is not cancelled before the trial ends
Annual price$25 USD per year
Included checks1,000 moderation checks per year
Extra checks$5 USD for 500 additional checks
Auto top-up triggerRemaining credits reach 50 or fewer
Spending controlAnnual top-up cap can be set after paid access is active
Credit usageOne credit is used when eligible content is successfully checked, not only when content is flagged
Backend outageNo credit is consumed unless a check is successfully processed
Example yearly costs​
These examples assume steady eligible content volume across a paid year, with automatic top-ups enabled and an annual top-up cap high enough to allow the required top-ups.
Approx. eligible checks per dayApprox. checks per yearEstimated paid-year cost
1 per day365$25 USD
3 per day1,095About $30 USD
5 per day1,825About $35 USD
15 per day5,475About $75 USD
50 per day18,250About $200 USD
100 per day36,500About $385 USD
Actual usage may be lower if content is outside your configured moderation scope where scope controls are supported, is otherwise not eligible for checking, is skipped by the short-lived cache, or if your forum activity varies seasonally.
What happens during outages or credit exhaustion​
AI Rules Moderation is designed to assist moderation, not sit in the critical path for normal posting.
If the hosted backend is temporarily unavailable, normal XenForo posting should continue. AI moderation checks may be missed or delayed during the outage. No moderation credit is consumed unless a moderation check is successfully processed.
If usable credits reach zero, AI moderation checks may pause until more credits are available, payment details are updated, an annual cap is increased where available, or credits are otherwise added.
Trial testing checklist​
After starting the trial and saving your settings:
  1. Enter a small set of clear test rules.
  2. If moderation scope controls are available, confirm your test account, node, and content type are inside the configured moderation scope.
  3. Submit a new post that clearly breaches one configured rule.
  4. Check XenForo’s approval queue.
  5. Review the AI moderation reason.
  6. Check the Admin CP audit log.
If the test content is eligible for review and the breach is clear, it should usually appear in XenForo’s approval queue within about a minute. This confirms the add-on, event dispatch, hosted backend, callback endpoint, and approval queue integration are working together.
Requirements​
RequirementMinimum
XenForo2.1.0 or newer
PHP7.2.0 or newer
Subscription statusActive trial or paid subscription
Network accessOutbound HTTPS access to the hosted moderation backend
Scope controlsXenForo 2.3.8 or newer required
On XenForo 2.3+, AI Rules Moderation uses XenForo’s native webhook system. On XenForo 2.1–2.2, the add-on uses its own compatibility driver to detect supported content create/update events and queue moderation checks. Moderation scope controls require XenForo 2.3.8 or newer for native scoped webhook dispatch.
Installation​
Upload and install the add-on using XenForo’s standard add-on installation process.
After installation, open the AI Rules Moderation setup page in the Admin CP, start the trial or connect the subscription, enter your forum details, write your moderation rules, choose moderation scope where supported by your XenForo version, then test the integration with a clear rule-breaching post that is eligible for checking.
Télécharger V1.0.7 :
