AI Connect for XenForo — WebMCP Protocol Bridge
Connect any MCP-compatible AI agent (Claude, ChatGPT, Cursor, and more)
directly to your XenForo forum using the WebMCP open protocol with
secure OAuth 2.0 + PKCE authentication.
How it works
AI agents discover your forum's capabilities via a standard
/.well-known/mcp.json manifest, authenticate via OAuth 2.0, and then
call MCP tools to read and interact with your forum — just like a
human user would, but programmatically.
Free Version — Included Tools
| Tool | Description |
Authentication
PRO Version (coming soon)
Advanced moderation and management tools:
Learn more about PRO at ai-connect.gold-t.co.il
Requirements
github.com/chgold/xf-ai-connect
Télécharger V1.1.9 :
Télécharger V1.2.21 :
How it works
xenforo.searchThreads | Search threads by keyword, forum, date ||
xenforo.getThread | Retrieve full thread with posts ||
xenforo.searchPosts | Search posts across the forum ||
xenforo.getPost | Retrieve a single post ||
xenforo.getCurrentUser | Get authenticated user info |Authentication
- OAuth 2.0 Authorization Code + PKCE flow
- Bearer token support
- Built-in rate limiting
xenforo.moderatePost— approve, reject, delete postsxenforo.banUser— ban/unban usersxenforo.moveThread— move threads between forumsxenforo.getForumStats— analytics and statistics- Priority support
Requirements
- XenForo 2.2.0+
- PHP 7.2+
- HTTPS recommended for OAuth flow
v1.2.10–1.2.21 — Permission system, personalised prompt, security fixes
### Version 1.2.21 — 2026-04-14
* Fixed: Users with
### Version 1.2.20 — 2026-04-14
* Fixed: Navigation link and footer icon are now automatically hidden for users/groups with
### Version 1.2.19 — 2026-04-14
* Fixed: PRO tool phrases were incorrectly stored under the free addon's
### Version 1.2.17 — 2026-04-14
* Added: Admin CP visual permission UI — per-tool rows grey out automatically when
### Version 1.2.14 — 2026-04-13
* Fixed: Users with
useTools = Never can no longer access the AI Connect info page or generate tokens### Version 1.2.20 — 2026-04-14
useTools = Never### Version 1.2.19 — 2026-04-14
- Fixed: Admin CP permission greying now works on fresh installs — switched to direct click listeners matching XenForo's own
PermissionChoiceapproach - Fixed:
js/chgold/aiconnect/admin-permissions.jswas missing from the release ZIP on fresh installs (addedbuild.jsonwithadditional_files)
addon_id, causing XenForo phrase validation errors (a-z, A-Z, 0-9, _ only) on fresh installs of external sites### Version 1.2.17 — 2026-04-14
- Added: Generic prompt metadata system — each module declares its own
getToolPromptMeta()so future tools appear automatically in thepersonalised prompt - Improved: buildPersonalizedPrompt() collects tool hints and URL examples from modules at runtime instead of a hardcoded table
- Security:
allowUnauthenticatedAccess()returningfalseadded to the Tools API controller — unauthenticated tool execution is now explicitly blocked at the framework level - Fixed: Admin CP permission JS file path corrected to
js/chgold/aiconnect/admin-permissions.jsper XenForo static file conventions
useTools is set to Never, matching XenForo's native depend_permission_id behaviour### Version 1.2.14 — 2026-04-13
- Added: Permission-aware manifest — authenticated requests to
/api/aiconnect-manifestreturn only tools the token owner can use; anonymous requests return the full list for discovery - Added: Permission-aware prompt generator —
/ai-connect/generate-tokenreturns a personalised prompt filtered to accessible tools
- Added: Full 3-tier permission system:
viewAiConnect,useTools(master switch), per-package (use_package_{id}), per-tool (tool_{module}_{tool}) - Added: Two Admin CP permission interface groups: AI Connect and AI Connect — Tools
- Added:
syncToolPermissions()andsyncPackagePermissions()— auto-registered on install/upgrade; third-party addons can hook in viaai_connect_sync_tool_permissions
- Added:
viewNavLinkpermission for controlling navigation link visibility per user group - Added: Session-based OAuth flow (
/api/aiconnect-oauth/start+/api/aiconnect-oauth/poll) - Fixed: Footer template uses
link()andbase_url()instead of hardcoded paths
