AdBlock Detector Pro v2.8.6
XF 2.2 / 2.3 AdBlock Detector Pro v2.8.6
Titre du sujet Titre du sujet AdBlock Detector Pro v2.8.6
Affichages Affichages 191
Recoup lost revenue from visitors using AdBlock Systems. Recommend AdBlocker visitors disable their AdBlocker, or force them to make a decision about Registration or Upgrade.
Separate overlays for guests and registered users so you can target registrations or user upgrades.
You decide what's best for your community and customize this addon as required. No two communities are the same, and neither should be your approach to recoup revenue.
Tutorial & Demo:
Recoup Ad Revenue:
  • Force users to be inconvenienced (the frequency is up to you)
  • Force users to disable their AdBlock System
  • Or, simply nag them a little over time
Promote Upgrades:
  • Do you offer an ad-free experience to user's that have upgraded?
  • Force users to upgrade if they don't want to disable their AdBlocker
Boost Registrations:
  • Disable the AdBlocker for Members and target visitors using AdBlock
  • Provide a link to register in the Overlay
Fully featured SEO-friendly anti-AdBlock system. Supports a full page overlay or a simple notice message. The choice is yours. The overlay or notice is customizable.
Features:
  • Redundant detection methods
  • Auto-generated scripts
  • Scheduled updates uniquely customized to your server
  • Fully mobile responsive
  • SEO-Friendly
  • Granular permissions per usergroup (by permissions or catch-all)
  • 4 overlay themes (dark, light, default and black out)
    • Ability to choose the primary color of the overlay using a color picker
    • Custom colour changes can be made in the theme.less
  • Override "ignore user group" for groups you NEVER want to see the anti-AdBlock
  • Auto minified (CSS/JS/HTML)
  • Ability to enable and disable the overlay
  • Ability to set the overlay delay timer in seconds
  • Ability to enable and disable the plugin
  • Ability to set the number of page views for nagging
  • Ability to set "nag on first page view always"
  • Ability to customize detection exclusions across XF templates
    • Default exclusion of common templates: login, register, error, account details, etc.
  • Improved responsive layout on small screen mobile devices
System includes:
  • All language in phrases
  • Supports multilingual translation
Click here for a complete list of updates.
Télécharger V2.4.9 :
Version 2.7.0 :
  • NEW: Added redundancy to ensure AdBlock detection that delays detection doesn't give false non-positive
  • NEW: Revised CSS animation detection to be more thorough and patient if initial check fails
  • UPDATE: Removed obvious attack vectors
  • UPDATE: Added additional obfuscation to animation frames
  • UPDATE: AdBlock Detection codebase updated from v11.0 to v12.0
  • FIX: Obfuscate promise resolutions and rejections
  • FIX: Obfuscate XHR requests
  • FIX: Obfuscate isSafari() function
Télécharger V2.7.0 :
Version 2.7.1 :
  • UPDATE: AdBlock Detection codebase updated from v12.0 to v12.12
  • FIX: Usergroup level permissions were being ignored since moving the permission-set group to "forum" from "general" (fixed)
  • FIX: Template compilation error with script variable
  • FIX: Skip obfuscation of functions removed prior to render
Version 2.8.0 :
  • NEW: Add Decoy Overlays to Prevent Eye-Dropping (new option) (default=on)
  • NEW: Add Enhanced Tampering Detection to Prevent Closure (new option) (default=off)
  • NEW: Add Periodic Visibility Checks (new option) (default=off)
  • NEW: Improved Fast Detection method
  • NEW: Randomized Bait Positioning: Replaced static positions with dynamic positioning methods (random left/top, transform: translate, or clip: rect) to improve detection with certain extensions in FireFox and Chrome
  • NEW: Added "Demo Admin Mode" (overlays will always detect&fire&display in the admin area for demo purposes when enabled)
  • UPDATE: AdBlock Detection codebase updated from (v12.12 to v13.00)
  • UPDATE: Upgrading jaybizzle/crawler-detect (v1.3.4 => v1.3.5)
  • UPDATE: Upgrading matthiasmullie/minify (1.3.73 => 1.3.75)
  • UPDATE: General performance optimizations for compiling cached overlays
  • UPDATE: Increase length of random variable names by 50% at minimum
  • FIX: Obey style-property for text color on 'Overlay inner window'
  • FIX: Made default install overlay for guest usergroup red (previous releases mistakenly had it orange)
  • FIX: EasyList now contains full class selectors, we need to ignore them when collecting Bait
  • FIX: Must skip nag delay if the user clicks the "I've Disabled AdBlock" (Thanks RoyalRumble)
Version 2.8.1 :
  • Fix: Nag delay now ensures that clicking "I've disabled AdBlock" makes sure the AdBlock extension was deactivated (thanks RoyalRumble)
    • If not deactivated the overlay ignores the "nag delay setting" and immediately reloads the overlay
    • If you have the "allow close overlay" disabled, this will force the user to deactivate their Adblock extension on the current page
  • Fix: Permission checks are now node-aware, using hasNodePermission() instead of the general hasPermission() check
    • This ensures that if you're force AdBlock on spefici forums, instead of all forums, that it will actually work as expected
  • Fix: Node-level permisson overrides are not obeyed and properly handled
  • Fix: Admin option tabs properly wrap on small devices
  • Fix: Remove delete files from past upgrade step that may have created/triggered XF Cloud installation issues
  • Update: Changed overlay color for guests to be the same red whether dark or light theme (looks best this way)
Version 2.8.2 :
  • Add: Detection for uBlock Origin Lite (thanks Wave)
  • Add: Remote Loading Detection (RLD) improvement
  • Add: Notice that RLD is required to detect newer v3 Chrome extensions such as "uBlock Origin Lite"
Version 2.8.3 :
  • Update: AdBlock Detection codebase from v13.00 to v14.0O
  • Add: Upgrade button on overlay now includes a CSS class: class="button button--upgrade"
  • Fix: Issue where [Enhanced Tampering Detection] was preventing detection when uBlock Origin Lite was active
  • Fix: Added [Remote Loading Detection] as a default enabled option for new installs
Version 2.8.4 :
  • UPDATE: Overlay close button uses a nicer glyph
  • UPDATE: Crawler detection performance improvement
  • UPDATE: Crawler Detection from (v1.3.5 => v1.3.6)
  • FIX: Overlay close button is properly positioned across all styles
Version 2.8.5 :
  • UPDATE: Replaced onerror-based script check with a network-level fetch() detection method
  • UPDATE: Improved ad-block resilience by avoiding timeout and error-handler patterns commonly targeted by filter lists
  • UPDATE: AdBlock Detection codebase from v14.00 to v15.0O
Version 2.8.6 :
- UPDATE: Crawler Detection from (v1.3.6 => v1.3.7)
Télécharger V2.8.6 :
    57.5 KB · Affichages: 37
    55 KB · Affichages: 33
    33.8 KB · Affichages: 34
    56.5 KB · Affichages: 37
    55 KB · Affichages: 30
    21 KB · Affichages: 35
    38.3 KB · Affichages: 36
    53.8 KB · Affichages: 32
    48.4 KB · Affichages: 32
    63.4 KB · Affichages: 36
    13.9 KB · Affichages: 35
    86.8 KB · Affichages: 36
    83.9 KB · Affichages: 32
