Add information to the account upgrades page to explain things like tax, invoicing refund policies, etc.
There are two information blocks you can add - one above and/or one below below the "Available upgrades" list. Both are optional - leave the body blank to hide the entire block.
Example usage :
The above settings will render the following two boxes on the Account upgrades page :
Télécharger V1.0.0 Bêta 1 :
Version 1.0.0 :
Example usage :
Version 1.0.0 :
- This release has simply bumped the version to 1.0.0 so the addon is no longer in "beta". There has been no change to the functionality and upgrading is optional.
- This version has been tested with XF v2.3 (previous version also worked)
Version 1.0.1 (2025-12-11)
- Remove files left behind by an upgrade, on XenForo 2.3 and laterVersion 1.0.2 (2026-09-22)
- Requires XenForo 2.2.0 or later
- The default text for the "Body before" option no longer refers to a list below it. When no upgrades are available there is no list, and this add-on's blocks take the place of XenForo's "There are currently no purchasable user upgrades" message. Existing installs keep whatever text they have set
