[XenVn] XFRM Right Sidebar Pro 1.0.0
XF 2.3 [XenVn] XFRM Right Sidebar Pro 1.0.0
Titre du sujet Titre du sujet [XenVn] XFRM Right Sidebar Pro 1.0.0
Réponses Réponses 8
Affichages Affichages 170
- XenForo 2.3.0+
- XenForo Resource Manager 2.3.0+
- [XB] XFRM: Purchasable Resources 2.0.1+
- [XenCustomize] Limit Resource Downloads 2.3.2+
An advanced sidebar enhancement plugin designed for XenForo Resource Manager (XFRM). With innovative download button integration technology and exquisite block-style design, it provides enhanced user information on your resource page.
Key Features :
  • Smart Download Button – Automatically detect and integrate official XFRM download logic
  • Modern Design – Modular card structure
  • Dark Mode – Full support for XenForo dark theme
  • Responsive Design – Perfectly adapts to mobile devices and different screen sizes
Intelligent Multiple State Identification:
The plugin can intelligently detect different resource states and automatically adjust the button style:
| Button Type | Color Theme | Trigger Condition | UI |
| 🔵Normal Download | Blue | Normal Resources | One-Click Direct Download |
| 🟠External Link | Orange | Resource Redirect | Go to External Site |
| 🟢Paid Purchase | Green | Paid Resources | Purchase Page Guide |
| 🟡Login Request | Yellow | Visitor Access | Login Popup | Elevated Privilege |
| ⚫Insufficient Privilege | Gray | Limited Privilege |
  • Full property inheritance — retains all functionality of the original button
  • Event monitoring synchronization — supports XenForo interaction with JavaScript
  • Compatibility with third-party plugins — works seamlessly with other XFRM extensions
  • Ability to change button colors in style settings
  • The plugin has an integrated internal currency when the [BR] Credits 1.1.0 or higher plugin is enabled. The resource panel displays your current amount of currency, allowing for more precise control when downloading resources for internal currency (only the first currency created in ACP is displayed)
  • The XF complaint system is used both to get a fast OS and to request a resource update
XenVn is a copyrighted add-on and is officially released at XenVn.Com.
merci beaucoup mon ami, c'est bien apprécier.
Where can you change the colors on these?
Je sais pas, j'ai pas tester cet addon.
Regarde dans les propriétés de style des addons requières.
