[XenDev] Advanced Reward & Badge System 1.0.0
XF 2.3 [XenDev] Advanced Reward & Badge System 1.0.0
Titre du sujet Titre du sujet [XenDev] Advanced Reward & Badge System 1.0.0
Affichages Affichages 8
Dernier message par Dernier message par Dojik
To use this add-on properly, you must install the XenDev Update Manager add-on:
XenDev Trophy System is a modern trophy and badge system designed to reward forum users’ activity, increase engagement, and strengthen community motivation.
The add-on delivers a visually rich experience across the postbit, user profile, and tooltip areas.
What Does This Add-on Do?
Encourages users to stay active
Creates healthy competition and motivation within the forum
Enhances profile and message areas with rich visuals
Strengthens community belonging
🦸‍♂️Display Areas
The add-on is automatically displayed in the following areas:
Postbit – Message area inside threads
User Profile
User Tooltip Profile
This way, the trophies and badges users earn can be seen across the entire forum.
🏅 Trophies System
The Trophies section is the core of the add-on.
You can define trophies automatically or manually based on users’ behavior on the forum.
Trophies represent a user’s status and prestige on the forum.
🎯 Trophy Criteria
Reaching a specific message count
Time spent on the forum
Receiving likes
Special events and contests
Manual assignment by an administrator
🎨 Icon & Color Customization
XenDev Trophy System provides a flexible structure for visual customization.
Single color icon support
Gradient coloring
Custom icon and color per trophy
Modern, theme-compatible design
With gradient and single-color options, it fully supports both dark and light themes.
🔐 Installation Guide
🗃️ Installation Steps
Download the add-on package to your computer.
Log in to the XenForo Admin Control Panel.
Go to Add-ons → Install/Upgrade.
Select the add-on archive and upload it.
After the upload is complete, enable the add-on.
No additional file editing is required after installation.
⚙️Admin Panel Settings
🧩 General Settings
Enable / disable the trophy system
Trophy ordering/sorting
Postbit, profile, and tooltip display controls
🎖️ Trophy Management
You can add new trophies or edit existing ones via the Admin Panel.
Trophy Name: Title shown to the user
Trophy Description: How it is earned
Trophy Icon: FontAwesome or a custom icon
Color Setting: Single color or gradient
Gradient-colored trophies draw more attention visually.
📍 Display Area Settings
Postbit trophy display
Profile trophy list
Tooltip trophy area
Each area can be enabled or disabled independently.
📷 Screenshot Captions
You can directly add the following texts under your promotional images.
🖼️ Postbit Trophy Display
In thread messages, the user’s trophies and badges are displayed in the postbit area with a modern design.
🖼️ User Profile Trophy Area
🖼️Tooltip Profile
In the tooltip that appears when hovering over a username, trophies can be viewed quickly.
🖼️ Admin Panel – Edit Trophy
Trophy icons, colors, and criteria can be managed easily via the Admin Panel.
🚀 Who Is This For?
XenForo forum owners
Community-focused platforms
Gaming, software, and technology forums
Administrators who want to build an active user base
