[XTR] Forum statistics 1.0.2
XF 2.2 / 2.3 [XTR] Forum statistics 1.0.2
Titre du sujet Titre du sujet [XTR] Forum statistics 1.0.2
Réponses Réponses 12
Affichages Affichages 711
Réaction Réaction 3
This add-on allows you to highlight your forum statistics on your website in columns of different color tones. As you know, we have previously presented a similar structure in the Ryzer Pro design regarding forum statistics. Now, we present a similar structure to you, our valued members, in a structure that can be added as a widget according to the request in this subject.
There is no copyright in the add-on. You can use it as you wish.
If you found this add-on useful, your positive emojis are welcomed.
Note : This statistic only works in conjunction with standard XenForo forum statistics. You can contact us for 3rd party statistical values.
Installation
Install the add-on then add XenTR forum statistics widget.
Add widget :
Style properties
Appearance > Styles > Your style - Style properties > ↓├ XenTR ┤ Forum statistics
RESULT
Sidebar forum statistics
Forum overview: Bottom
Version modifier par moi pour xenforo 2.3 : Fix icones
Télécharger V1.0.1 modier pour xenforo 2.3 :
Version 1.0.2 :
  • Add-on templates updated to XF 2.3.x
  • Confirm XF 2.3.x Support
  • PHP 8.3 compatibility update.
Pour voir ce contenu caché, votre nombre de messages doit être supérieur ou égal à 20.
Merci je vais testé celui-ci car j'en ai un ([XenGenTr] Forum istatistikleri) mais il me fait pas mal erreur
Merci pour ce partage
Ajout de la version modifier pour xenforo 2.3 :)
Ajout de la version 1.0.2 :)
