Visualizes the user's position on the User Title Ladder.
You can choose a default image for the ladder levels, as well as custom images for each level.
You can add custom CSS in the style properties so as to create a progress bar effect (example given in the add-on), or other effects of your choice.
You can choose custom images for each level in the User Title Ladder admin screen
You can choose your default image and add CSS in the style properties
Version 1.0.0.3: XF 2.3 compatibility release
- The add-on is now compatible with both XF 2.2 and 2.3. If you encounter any issues please don't hesitate to report them.
Télécharger V1.0.0.3:
