XenForo Importers 1.4.0
XF 2.2 XenForo Importers 1.4.0
Catégorie Catégorie Generale
Titre du sujet Titre du sujet XenForo Importers 1.4.0
Réponses Réponses 6
Affichages Affichages 434
Dernier message par Dernier message par marek
XenForo Importers 1.3.2 is now available for all licensed customers to download. If you have already successfully completed your import, you will not need to upgrade.
Download XenForo Importers 1.3.2
or
Upgrade directly from within your control panel
Some of the changes in XFI 1.3.2 include :
XenForo Importers requires XenForo 2.1 or later.
Installation, Upgrading and Configuration
Please see our XenForo Importers manual page for more information about importing.
Today, we have released XenForo Importers 1.0.1, a maintenance release for our importers add-on. This release primarily targets bug fixes:
Some of the changes include :
  • vBulletin: Only rewrite quotes where a post ID is specified in the quote BB code.
  • vBulletin: Re-implement the blogModerators step and disable the blogUsers step.
  • vBulletin: Prevent errors when importing smilies if there are no smilies to import..
  • vBulletin: Process buddy/ignore lists correctly.
  • vBulletin: Double-encoded strings (usernames, titles etc.) are now not double-encoded
  • General: Importers are now expected to decide for themselves whether each field should have HTML entities decoded or not. You can either do this using EntityEmulator->set($fieldName, $value, [EntityEmulator::UNHTML_ENTITIES => true]) or if the value is not going to automatically pass to convertToUtf8(), you can use convertToUtf8($value, null, true) by calling it directly.
  • General: Fix some mis-titled templates and phrases in the initial release.
For the full list of bug fixes, see the Resolved bug reports forum.
Télécharger V1.3.2 :
XenForo 2.2.0, we are also releasing updated versions of each of our official add-ons.
Note:
Only the PHP version requirements have changed here. However, even if you're running PHP 7.0 we strongly recommend upgrading to PHP 7.4 at the earliest opportunity for improvements in speed, security and stability. We also recommend MySQL 5.7/8.0 (or equivalent).
Installation and upgrade instructions
Full details for how to install and upgrade XenForo can be found in the XenForo manual. One-click upgrades from XF 2.1 are possible. Once the XF 2.2 upgrade has been complete, the official add-ons should be upgraded as well, otherwise you may run into incompatibilities.
Télécharger V1.4.0 :
Ajout de la version 1.40 :)
