Conditions d'utilisation et règles
Conditions et règles a lire !
Politique de confidentialité
Quelles informations nous détenons sur vous ?
Contacter le Staff
Un problème ? Une question ?
    Télécharger
    Compatible Tout SPRX
    et encore d'autre Mod !
    Télécharger
XF 2.1 XenForo 2.1.8 Full / Upgrade Patch 2
Nom de la catégorie Generale
Titre XenForo 2.1.8 Full \/ Upgrade Patch 2
Auteur de la discussion OTuGaMoDz
Date de début
Réponses
Affichages
Dernier message par Damss
OTuGaMoDz
Partenaire societyfrenchmodding.net
Donateur
Top réponses
13
Salut la communauté
XenForo 2.1.8 is now available for all licensed customers to download. We recommend that all customers running previous versions of XenForo 2.1 upgrade to this release to benefit from increased stability.
Veuillez vous Identifier ou vous Inscrire pour afficher le contenu masqué.
Some of the changes in XF 2.1.8 include:​
  • Attempt to merge reactions when merging posts​
  • Only hydrate autoIncrement relation fields if there is no value in the parent entity. If the field has a value in the parent, an exception is now thrown.​
  • Use \ZipArchive::OVERWRITE flag when creating add-on zip to maintain compatibility with newer libzip versions​
  • Ensure more consistent sorting is used for class extensions, code event listeners and template modifications.​
  • Fix method checking when looking for API methods with versions appended.​
  • Use optimal batch sizing when rebuilding templates and phrases.​
  • Don't allow moderators to delete / edit warnings they have given if they have no permission to.​
  • Update GitHub OAuth implementation to use header authorisation.​
  • Handle rebuilding the active warning points in the User rebuild job.​
  • Supress warnings when closing file pointer after copying file​
  • Ensure a boolean value is returned when checking viewing permissions for conversations.​
  • When importing deletion log entries, ensure the username and reason do not exceed the allowed max lengths.​
  • Update register navigation item to ensure registration is enabled​
  • Add widget data attributes to expanded new thread widget​
  • Only fetch member stat results once on the overview page​
  • Allow connected account providers to provide additional auth params​
  • Only enqueue a reaction score rebuild when a reaction's score has changed, and simply rebuild scores for all reactions​
  • Correctly identify Android version in the attachment manager​
  • Upgrade jQuery to 3.4.1.​
  • Validate parent IDs correctly when inserting tree structured data.​
  • Prevent spam cleaner error when deleting a thread started by a spammer which has a redirect thread pointing to it.​
  • Add a content template for user reports to improve extensibility.​
  • Prioritize quick reply editor when multi-quoted quotes are inserted.​
  • Add a minimum width to user change log cells​
  • Add account email check to various places before sending mail​
  • Offset the select-to-quote tooltip whenever touchevents are supported.​
  • When rendering an unfurl do not double escape the proxied version of the URL.​
  • Force max length constraint when handling a user ban reason.​
  • Re-implement shortening of display text for very long URLs.​
  • Log moderator attachment deletions to the moderator log.​
  • Display error when trying to add template modification when not in development mode.​
  • Workaround an issue with multiple color pickers which could prevent some color pickers from behaving as expected.​
  • When previewing, ensure that sticky form submit rows stay stuck to the right place.​
  • When importing paid subscriptions from vBulletin ensure user group changes are correctly logged.​
  • Add a separate 'following' phrase for members others follow​
  • Check preg_last_error() when processing template modifications​
  • Improve news feed handler attachment handling​
  • Prevent an error related to cache clearing of entity relations with an empty condition.​
  • Reverse some changes related to template editing syntax highlighting which may actually break syntax highlighting entirely in some cases.​
  • Echo a list of allowed extensions back in the error message given when a file that does not have an allowed extension is uploaded.​
  • Include file and line number in exception XML response​
  • Throw an error exception when a ban fails to apply​
  • Handle failed bans in the warning point change service​
  • Ensure that emoji conversions are done as expected for all characters.​
  • Prevent a URL parsing error when following an HTTP request redirect to a path that starts with a "/" and contains a ":".​
  • Improve styling of responsive data lists, particularly with checkboxes that have headings​
  • Allow attachment data manipulation before copying files​
  • Implement search source method to determine if a query is empty​
  • Do URL canonicalization on the contact page and ensure that we link to misc/contact consistently (no trailing slash).​
XenForo 2.1.8 Patch 2 Released
We have identified an issue in 2.1.8 that may cause certain template modifications in add-ons to not be applied correctly. This issue is discussed in more detail in
. In order to resolve this, we have released XenForo 2.1.8 Patch 2.
Lien de téléchargement version full :
Contenu caché
Vous devez répondre au message pour voir ce contenu.
Lien de téléchargement version upgrade:
Contenu caché
Vous devez aimer ce message pour voir ce contenu.
bobob10
Membre
Membre
Top réponses
0
XenForo 2.1.8 Patch 1 publié
Nous avons corrigé deux problèmes dans XenForo 2.1.8 qui provoquaient des erreurs ou un comportement inattendu:
Erreur relative aux points d'avertissement lors de la reconstruction des caches utilisateur
Erreur lors de l'envoi d'un reçu de paiement avec mises à niveau utilisateur / achetables
Contenu caché
Version Nulled par moi :P
Tony
Membre
Membre
Top réponses
0
Pas de citation
Pas de citation
Salut tu as pas le 2.18 upgrade ?
OTuGaMoDz
Donateur
Top réponses
13
XenForo 2.1.8 Patch 1 Released
We have fixed two issues in XenForo 2.1.8 which cause errors or unexpected behavior:
  • Error relating to warning_points when rebuilding user caches
  • Error when sending a payment receipt with user upgrades/purchasables
bobob10
Membre
Membre
Top réponses
0
XenForo 2.1.8 Patch 2 publié
Nous avons identifié un problème dans 2.1.8 qui peut entraîner l'application incorrecte de certaines modifications de modèle dans les modules complémentaires. Ce problème est abordé plus en détail dans
. Afin de résoudre ce problème, nous avons publié XenForo 2.1.8 Patch 2.
Contenu caché
Contenu caché
