Télécharger V2.1.5 Fix 2 :
Version 2.1.6 Changed : People can't register (@AngelArs #Report)
Added : Adds an option to choose at the time of registration in which type of user group it will be mit (primary or secondary). (@leoterik #Suggestion)
Version 2.1.6 fix 1 Changed : Error while registering with a connected account provider(@leoterik #Report)
Version 2.1.6 fix 2 Changed : At the time of registration, an error was generated because of the line: 12 in the
Version 2.1.7 Added : User group on singup (by invitation code). (@est3ban129 #Suggestion)
Version 2.1.7 fix 1 Changed : The setup for the table:
Version 2.1.7 fix 2 Changed : The column
Version 2.1.8 Added : Possibility of generating more than one token. (@est3ban129 #Suggestion)
Version 2.2.0 Added : Option on invite panel to sending the invitations by email to the guests. (@yin9 #Suggestion)
Note : This version of the add-on is now compatible with the version 2.2.0 Beta 1 and higher of XenForo.
Version 2.2.1 Added :
Implement together with the plugin paid registration. (After the payment of the registration with the addon: [AddonFlare] Paid Registrations the user will receive an invitation code to register. This invitation code will be sent with the email sent by the addon: [AddonFlare] Paid Registrations ) (@est3ban129 #Suggestion)
Version 2.2.1 fix 1 Added : Code cleaned.
Télécharger V2.2.1 fix 1 :
Version 2.2.1 Fix 2 Changed : Guests and members can generate tokens via commands in the console.
Version 2.2.1 Fix 3 Changed : At the moment, tokens are unusable due to a flawed permissions check. (@DragonByte Tech #Report)
Version 2.2.2 Changed : Fixed some code in our PHP. (@DragonByte Tech #Report / #Report @TickTackk #Report)
Added :
New permission : users with a number of posts can invite. (@elduque #Suggestion)
Now you can make an invitation via email. (@xlegends)
Version 2.2.2 Fix 1 Changed : Missing JS files. (@tomnjerry74 #Report)
Télécharger V2.2.2 fix 1 :
Version 2.2.2 Fix 2 :
- Changed There was a permission error ("X message to use the invitation system") it was necessary to have +1 message compared with the permission.
Version 2.2.3 : Added a permission to force users to send the invitation code always by email.
Version 2.3.0 :
Added : Now you can purchase invitations.
Note : This version of the add-on now require PHP 8 and higher.
Télécharger V2.3.0 :
Version 2.3.0 Fix 1 :
- Changed : Invite filters not working (@tbqhwy #Report)
- Added : Now when an invitation is sent by email in the admin panel, it will check if the email is not already associated with an invitation or if it is already registered. (#Suggestion @zoldos )
Version 2.3.1 Fix 1 :
- Changed : Unable to send email invitations from admin panel since update 2.3.1 (@zoldos #Report)
Télécharger V2.3.1 Fix 1 :
Version 2.3.1 Fix 2 : Changed Error while attempting to send email invite from User Control Panel (@tbqhwy #Report)
Télécharger V2.3.1 Fix 2 Lien Mega :
Lien Mediafire :
Version 2.3.2 update:
Changed :
_ The subject of the e-mail was wrong (@zoldos #Report)
Added :
- Added an option that allows when a user wants to send an invitation code by email, it checks if the user is already registered or has already been invited.
Télécharger V2.3.2 :
Version 2.3.2 Fix 1 :
- Changed : Invite system not checking if valid e-mail upon submit (@zoldos #Report)
Télécharger V2.3.2 Fix 1 :
Version 2.4.0 Changed : Code cleaned.
Note :
- This version of the add-on is now compatible with the version 2.3.0+ of XenForo.
- This version of the add-on now require PHP 8.0+.
Version 2.4.0 Fix 1 Changed : If you deactivate the option to buy invitation codes, the purchase page will remain accessible.
Note : This fix is also available for XenForo 2.2 (Addon version: 2.3.2 Fix 2).
Version 2.4.1 Added : New option : now unregistered users can purchase invitations from registration form.
Note : This version of the add-on is only compatible with the version 2.3.0+ of XenForo.
Télécharger V2.4.1 :
Version 2.4.1 Fix 1 Changed :
- Page doesn't work in invitation list on Member profile
- Typos errors (@tinkbert #Report)
Version 2.4.1 Fix 2 Changed : With the latest update, it no longer uses the option for the number of items per page.
Télécharger V2.4.1 Fix 2 :
- Added ability to include html in invitation emails
Note : This fix is also available for XenForo 2.2 (Addon version: 2.3.3).
Télécharger V2.4.2 :
- This add-on allow you to generate invitation codes to join your forum and more. Invitation code is required for registration, you can manage your codes easily !
- Options :
- Code required during registration
- Tokens per page
- Validity of the invitation code :
- Permanent
- Until X days
- Add token :
- Title
- User groups
- Maximum usable
- Add token user :
- Title
- User
- Maximum usable
- Alert when a member registered using your invitation code
- Profile tab : Invitation
- List code :
- Filters
- Show invited users
- User criteria for trophies/notice :
- User has invited at least X users
- User has invited no more than X users
- Search criteria in the ACP :
- Most invitations
- Member stats : Most invitations
- Banned users :
- User name
- Ban length :
- Permanent
- Until
- Reason for banning
- Permissions :
- Admin : Manage invitation system
- User : Can invite someone
- This add-on does not include branding.
- Download and unzip it.
- Copy the src/addons/XenSoluce/InviteSystem directory to your server.
- From the AdminCP install the add-on.
InviteSystem\XF\Service\User\Registration.php
file (@CheeseSandwich #Report)Version 2.1.7 Added : User group on singup (by invitation code). (@est3ban129 #Suggestion)
xf_xs_is_user_group_code
of the last update was missing.Version 2.1.7 fix 2 Changed : The column
type_user_group
is missing in the table: xs_is_token
. (@est3ban129 #Report)Version 2.1.8 Added : Possibility of generating more than one token. (@est3ban129 #Suggestion)
Added :
Version 2.3.0 :
Lien Mediafire :
Changed :
Added :
Note :
Version 2.4.2 added :- Added ability to include html in invitation emails
mhy.png237 KB · Affichages: 45
loj.png210.1 KB · Affichages: 43
juo.png203.8 KB · Affichages: 34
bgi.png343.2 KB · Affichages: 32
crm.png174.1 KB · Affichages: 35
ngt.png232.2 KB · Affichages: 32
mou.png212.4 KB · Affichages: 31
lhp.png292.4 KB · Affichages: 30
jfe.png215.6 KB · Affichages: 31
dym.png225.4 KB · Affichages: 32
mgr.png223.6 KB · Affichages: 29
fum.png200.5 KB · Affichages: 27
kez.png174.3 KB · Affichages: 29
fez.png272.5 KB · Affichages: 26
jea.png253.8 KB · Affichages: 27
szu.png188.5 KB · Affichages: 39
kiy.png286.6 KB · Affichages: 25
gtl.png277.1 KB · Affichages: 32
