Addon will allow to replace the standard links in the footer with the icons Font Awesome.
Features
Télécharger V2.1.4 :
Version 2.2.4 The addon has been redesigned
NOTE : This version of the addon requires a new installation.
Changelog :
The addon has been slightly redesigned
Now you can specify your own color for each footer icon.
The addon had a conflict with the "Remove RSS" addon by AndyB, now this problem is solved by adding similar functionality.
Added option to disable access to RSS by link, which also disables the RSS icon.
If you just want to hide the RSS icon, you can do this in the style properties.
P.S.
This version will work on both XF 2.1.x and 2.2.x.
If you want additional icons in the footer, do not hesitate to write.
Télécharger V2.2.4 :
Features
- You can set the icon on the standard link
- You can combine the icon and link
- You can leave only the link
- You can adjust the intensity for each icon
- You can set the color of the icons
Changelog :
P.S.
