Développé par FIX94, Wii DS Rom est une nouvelle application destinée aux utilisateurs de Wii première génération, mais aussi de vWii.
Wii DS Rom permet d'envoyer des ROM DS d'une Wii vers une DS à l'aide de Download Play, mais aussi désormais avec HaxxStation car cette version v2.0 rajoute cette possibilité.
wii-ds-rom-sender
This application will allow you to send NDS ROMs via a Wii to a DS using Download Play.
Please note that if your DS is not patched with FlashMe and you dont use HaxxStation then you can only send over Official Demo ROMs.
To make use of HaxxStation, get the US version of "DS Download Station - Volume 1" renamed to "haxxstation.nds" on the root of your sd card.
All you have to do is put your .nds/.srl files into a "srl" folder on your sd card, get the current version of this program from the "releases" tab and start it via the homebrew channel.
After it loaded up just select the file you want, download it on your DS and play it!
v2.1
added option to change delay timing (only required when you have send problems)
[HIDETREPLYHANKS=1]Téléchargement : Wii DS Rom Sender v2.1 (maj 9h00)
[/HIDETREPLYHANKS]
Source : L-S
