Now you can set icons in few minutes. With this plugin you can:
- set image for forum node, page, link or category
- set font awesome icon for forum node, page, link or category
- set width for icon
- turn on/off animation effect for new icons
- turon on/off border for image icons
- turon on/off border radius for image icons
- set color for border
- set font awesome and image icon in the same node!
Version 2.0.1 ADD :
you can use spritemaps in png, jpg, svg
on/off borders for spritemap node icons
animations for spritemap node icons
on/off unread color node icons
setting for unread font awesome color
sample spritemap in png (descriptions how to set icons are inside each forum edit form)
Télécharger V2.0.1 :
Version 2.0.4 XF 2.2 support :
This is major update.
fixed problems with 3rd party plugins compatibility
fixed problems with icon sizes
fixed missing phrases
reworked SVG support, now sprites need to be .SVG
only one field to set svg for forum icon
reworked subforum list icons
reworked templates to be more performance friendly
added sizes for font awesome subforum icons
added sizes for images subforum icons (SVG inherits it)
Plugin should work fine on XF 2.2 now. If you have any problems please contact via Discord to get fastest support.
Télécharger V2.0.4 :
Version 2.0.5 : fixed problem with editing link forums
Télécharger V2.0.5 :
Version 2.0.6 fixes :
fixed problem with display of subforum icons
fixed problem with template error for comments icon
Version 2.0.7 animations fix : fixed problem with button for turnin on/off animations
Version 2.0.7.1 small fix : fix for subforum icon nodes animations
Télécharger V2.0.7.1 :
Version 2.0.7.2 fix : small fix for template modification process to avoid problems with implementing css
Télécharger V2.0.7.2 :
Version 2.0.8.2 news features + fixes
icons list in forum list panel
two types of icons (for dark and light themes)
some small fixes
Télécharger V2.0.8.2 :
Version 2.1.0 Change log : File Upload
Télécharger V2.1.0 :
