XF 2.0 / 2.1 [TH] XPress - A theme and bridge for bringing WordPress into XenForo 1.1.2 / 1.1.3 Patch Level 4
Titre du sujet Titre du sujet [TH] XPress - A theme and bridge for bringing WordPress into XenForo 1.1.2 \/ 1.1.3 Patch Level 4
Réponses Réponses 3
Affichages Affichages 897
Dernier message par Dernier message par poptastico
XPress
XPress bridges XenForo and WordPress together for a smooth integration making managing your software systems easier and creating a fluid user experience.
Many platform directors struggle to keep two distributed software systems consistent. You have to maintain the theme and template separately which can be quite costly, to not only build but to maintain over time as well. You also need to manage two comment systems, two user accounts, two staff and usergroup levels, two subscription systems, and more. XPress lets you choose your preferred tools and bridges them to the other software.
XenForo is regarded as one of the most easily customizable and powerful forum platforms on the market. And WordPress powers roughly 1 in 5 websites on the internet. Pairing them together only made sense. Please try our demo to see this seamless integration in action.
To make managing platforms simple, we created XLink which is included with XPress and must be downloaded and installed separately. It is required to use XPress. XLink provides one location to link and manage your platforms, like WordPress (requires XPress) and MediaWiki (requires XWiki). Add new platforms with just a few clicks, access a list of linked users per platform, and more right from XLink.
Integrating different platforms can be a complicated process. Our experienced team of experts is here to help! We offer the option for professional installation during checkout. Our team will help install XPress on existing platforms, help with basic configuration, and assist in resolving server errors that may occur. If you choose to purchase the add-on without the professional installation service and need help resolving server errors that may occur, you will be charged at our standard hourly rate.
Please Note: Custom add-ons, customizations, and server configuration can prevent XPress from working properly. Should you encounter an issue, please create a ticket here. If the issue is due to custom add-ons, customizations, or server configuration we will offer a full refund if reported here within 30 days. ThemeHouse is at the sole discretion on refunds and you must allow us time to help fix the issue.
Wondering about performance impacts? Take a look at the results from some tests we ran for UI.X, XPress, XWiki, and XLink here.
Same one design, two softwares
With a one time setup, XPress is a cost-effective, time saving tool to help make sure you're always in sync.
Sign on with either account
With single sign-on capabilities, users can sign in through either platform account. This means either XenForo or WordPress membership plugins can be used, no limitations.
Share memberships and ads, both ways
Premium content and advertisements can now be shared seamlessly between XenForo and WordPress. Set it up once and you're done.
Compatible with UI.X and UI.X Pro
Or any theme of your choosing! XPress is highly extendable and can be implemented in just a few easy steps.
Administrator Features
  • Utilize XLink for platform management (XLink is included with XPress and must be downloaded and installed separately. It is required to use XPress.)
  • Compatible with any XenForo theme - WordPress viewers will use your XenForo theme
  • Customize the appearance of your articles through style properties easily
  • Choose if you would like to use the featured article image as the thread cover
  • Share premium content and advertisements seamlessly between XenForo and WordPress
  • Use your XenForo Widgets in WordPress and WordPress Widgets in XenForo
  • Add the WordPress breadcrumb to your XenForo site
  • Importer for XenPorta 2, CTA Featured Threads, and XenBlog
Article/Thread Features
  • Post WordPress articles as threads in the forum
  • Promote threads in your community to WordPress posts
  • Unified comments - sync comments and thread posts or keep WordPress comments
  • Threads instead of comments - show the native XenForo thread experience directly under your WordPress posts
  • Improve WordPress commenting experience. Replace your native WordPress comments with a full XenForo thread embed, or use BB Codes and Ajax submit on native WordPress comments. Comments are also fully synced across platforms!
  • Hide user signatures in blog comments
  • Select a default prefix that will be automatically applied to all threads created by XPress that are eligible to have the selected prefix
  • Several functional tags can be added to a WordPress post to support different functionalities like creating feature posts, redirecting WordPress posts to XenForo threads, and more
User Management Features
  • Synchronize, automate, and manage WordPress user roles with the XLink user promotion system
  • Automatically link existing accounts and create new WordPress accounts for all your XenForo users
  • Shared login and single sign-on turn logging into both platforms into a single action
  • Synchronize user information across platforms. Pull XenForo avatars, usernames, biographies and more into WordPress, and redirect WordPress author pages to XenForo member profiles
User Features
  • Single sign on
  • Search through WordPress and XenForo using unified search
Télécharger V1.1.2 :
Xlink pour Xpress :
Version 1.1.3 PL1 Changes :
Fixes an installation issue introduced in the latest patch.
Custom Post Types can now be manually enabled in the WordPress configuration (see documentation for more information).
Added a number of filters and hooks for easier extension (see documentation for more information).
Now sending all hooks, filters and API endpoints through the XenForo class proxy for easier extension (see documentation for more information).
Resolved an issue that prevented users from being logged out of WordPress if they logged out of XenForo with SSO enabled.
Resolved an issue that prevented scheduled posts from creating a XenForo thread.
Manually deleting WordPress accounts now also deletes the account link from XLink, resolving an issue that would prevent new accounts with the same email address from being linked.
Resolved an issue with installations based on php-fpm.
The WordPress XPress dashboard item no longer shows for user accounts without administrator roles.
No longer stops duplicate XenForo comments from being inserted into the WordPress database.
Télécharger V1.1.3 PL 1 :
Version 1.1.3 Patch Level 2 Changes :
Resolved a couple of issues with filters not receiving all necessary arguments.
Resolved a number of namespacing issues when throwing login errors.
Resolved an issue with category breadcrumbs not correctly showing on pages and category archives.
Resolved an issue with XenForo>WordPress widgets not respecting display conditions.
Resolved an issue with XPress Category page criteria not saving correctly.
Resolved an issue with XPress Category page criteria not correctly triggering on category archive pages.
Resolved a number of assorted hook issues.
Télécharger V1.1.3 PL 2 :
Version 1.1.3 Patch Level 2 released ! Changes:
Télécharger V1.1.3 PL 4 :
XF 2.0 / 2.1 / 2.2 / 2.3  Notice Time Replacables 2.4.0
XF 2.0 / 2.1 / 2.2 / 2.3  AndyB Birthday thread 2.5
Ajout de la version 1.1.3 Patch Level 1 :)
Ajout de la version 1.1.3 Patch Level 4 :)
