Discussions [Switch] iyenal vous propose son moteur/SDK Gen7 Engine
Titre du sujet Titre du sujet [Switch] iyenal vous propose son moteur\/SDK Gen7 Engine
Affichages Affichages 627
Gen7 Engine est un moteur développé par iyenal depuis plusieurs mois, son premier objectif est de faciliter le développement de divers homebrews.
Gen7 Engine étant suffisamment performant pour en faire un moteur complet, iyenal a donc décidé d'en faire un kit de développement complet.
Et depuis lors, tout a été conçu pour les novices, afin que chacun puisse créer son propre homebrew avec très peu d'exigences et de connaissances requises !
Note du développeur :
Gen7 Engine is an engine which I developed now for many months, at first to facilitate me the development of various homebrews. But after some point, Gen7 Engine was enough mature and developed... to make it a full engine, so I decided to make it a full software development kit. And since that, everything have been designed with novices in mind, so everyone can make his own homebrew with very little requirement, and I hope make quality ones.
  • A multiplatform engine
    Gen7 Engine uses wrappers (SDL is planned) which makes its code versatile on any platform where the wrapper is supported. You can use Gen7 Engine to compile for the Wii (I already done so), Wii U, 3DS, even the Dreamcast or mobile, as SDL are ported on these platforms. As I didn't had enough time to test Gen7 Engine on other platforms than the Switch, I disabled Wii support for security reasons.
  • Visual Programming
    Yes, you can make your own homebrew without programming knowledge requirement! With blocks, compose the code of your application using the smart system of visual programming providen by Gen7 Engine. And in the future, node programming will be supported to be able to make FSM states (Finish-State System) and global view hierarchy to empower your programmation.
  • Multiplatform itself
    What better to be able to program anywhere? Gen7 Engine interface system is designed using OpenGL and hybrid Javascript which is supported on a wide range of devices, like mobile or tablets! And maybe even consoles in some cases! To compile you code in these devices, a cloud compilation system will be realized to set your own server or Gen7 Engine services so you can test your productions without the need of your computer.
  • Extend your Gen7 Engine Installation
    Customize Gen7 Engine for your needs and even use your own C code and librairies to not be limited by the engine, or use G3E files to extend the available events for your application and to share them.
Source : https://gbatemp.net/...-switch.522648/
