REMARQUE :
Cette version concerne XenForo 2.1.x. N'essayez pas de mettre à niveau vers cette version si vous utilisez XenForo 2.0.x
Améliorations :
Ajout de deux nouvelles options de widget :
1- Activer le style de barre latérale - Si vous l'utilisez dans la barre latérale et souhaitez le même en-tête que le reste des widgets de la barre latérale.
2- Masquer la date du message - Si vous ne voulez pas afficher la date et l'heure du message.
Nouvelle option :
Ajout d'une option permettant de tagé rapidement un utilisateur via le bouton @ à côté du nom d'utilisateur. Il mettra également en évidence le message pour l'utilisateur tagé.
This is a shoutbox widget that you can add in any of the available widget positions.
Options:
When scrolling at the bottom of the shouts, older shouts will be automatically loaded.
If you want a feature rich chat application, please see my add-on.
Shoutbox demo is available here:
New Features & Improvements :
Added archive with option to search by user and keywords. You can set how many messages to show per page in admin options. This feature requires the "View archive" user group permission.
Added new admin option called "Shoutbox refresh timeout" that allows you to stop refresh interval if the user is not active in the Shoutbox for more than x minutes. This feature existed before but it was set to 10 minutes and could not be changed.
Added auto-scroll toggle to allow reading older messages without being forced back. This activates/deactivates when you scroll.
Loading older messages is now smother.
Made images smaller with CSS to take less space.
Améliorations :
Nouvelle option :
Options:
- Minimum age required - Enable shoutbox based on user's age.
- Shoutbox refresh interval - Allows you to set refresh interval for new messages. This option can be disabled.
- Shoutbox refresh timeout - Stop refresh interval for inactive users after x minutes
- Maximum shout length - Set the maximum allows shout length.
- Minimum time between shouts - Flood check (with user group permission to bypass it)
- Shout display limit - Set the maximum number of shouts to display on page load.
- Delete shouts older than - Allows you to auto-delete shouts older than x days.
- Auto prune shoutbox every x hours.
- Auto prune message.
- Enable navigation tab - Allows you to chat in a dedicated page
- Enable sound - Enable sound notification for new shouts.
- Enable avatars - Display user avatar in shout.
- Allow BB codes - Controls if BB codes are parsed or not.
- Enable auto link - Auto link/embed URLs and media sites.
- Enable smilie button - For easy smilie access.
- Reverse ordering - Place input box at the bottom and display new messages from the bottom to the top
- Quick user tagging button with shout highlight.
- Footer - Allows you to add custom content (text, ads, etc) in the shoutbox footer.
- Thread ID - Post shouts in a dedicated thread as well.
- Thread message minimum length - Set minimum length required for shouts.
- Ban users with ban list
- Archive with option to search by user and keywords
