Conditions d'utilisation et règles
Conditions et règles a lire !
Politique de confidentialité
Quelles informations nous détenons sur vous ?
Contacter le Staff
Un problème ? Une question ?
    Télécharger
    Compatible Tout SPRX
    et encore d'autre Mod !
    Télécharger
Xenforo 2.x.x Shoutbox by Siropu 1.3.5
Nom de la catégorie Add-Ons
Titre Shoutbox by Siropu 1.3.5
Auteur de la discussion laurent68
Date de début
Réponses
Affichages
Dernier message par MathiasFR83
Top réponses
41
  • Auteur de la discussion
  • Admin
  • #1
This is a shoutbox widget that you can add in any of the available widget positions.
Options:
  1. Shoutbox refresh interval - Allows you to set refresh interval for new messages. This option can be disabled.
  2. Maximum shout length - Set the maximum allows shout length.
  3. Shout display limit - Set the maximum number of shouts to display on page load.
  4. Delete shouts older than - Allows you to auto-delete shouts older than x days.
  5. Auto prune shoutbox every x hours.
  6. Auto prune message.
  7. Enable navigation tab - Allows you to chat in a dedicated page
  8. Enable sound - Enable sound notification for new shouts.
  9. Enable avatars - Display user avatar in shout.
  10. Allow BB codes - Controls if BB codes are parsed or not.
  11. Enable auto link - Auto link/embed URLs and media sites.
  12. Enable smilie button - For easy smilie access.
  13. Reverse ordering - Place input box at the bottom and display new messages from the bottom to the top
  14. Footer - Allows you to add custom content (text, ads, etc) in the shoutbox footer.
  15. Thread ID - Post shouts in a dedicated thread as well.
  16. Thread message minimum length - Set minimum length required for shouts.
It has user group permissions for using shoutbox, editing/deleting shouts, prune shoutbox (/prune)
When scrolling at the bottom of the shouts, older shouts will be automatically loaded.
Improvements :
Enable sidebar style - If you use it in the sidebar and want the same header as the rest of the sidebar widgets.
Hide shout date - If you don't want to display shout date & time
Improvements & Bug Fix :
Added option to set a user ID for automated bot prune messages.
Fixed an issue with sound path in certain instances.
Contenu caché
Vous devez répondre au message pour voir ce contenu.
OTuGaMoDz
Partenaire societyfrenchmodding.net
Donateur
Top réponses
13
merci bien l'ami, je vais tester cette shoutbox, j'ai des erreurs avec la chat siropu
Message automatiquement fusionné :
t'as pas la traduction par hasard ? ;)
pas besoin je viens de trouver ;)
Top réponses
41
  • Admin
  • #3
Moi aussi sur la chatbox j'ai des problèmes quand j'affiche les notifications des nouveaux messages, j'arrive plus a poster sur le forum,
j'ai une erreur comme quoi je doit avoir un minimum 50 caractères.
OTuGaMoDz
Donateur
Top réponses
13
mais tu as ce erreur de caractères quand tu veux poster quelque chose c'est ca?
Top réponses
41
  • Admin
  • #5
Oui seulement quand j'active les notifications des nouveaux topic et messages dans les options de la chatbox.
OTuGaMoDz
Donateur
Top réponses
13
ah dacc, moi j'ai un erreur du chat dans la console je sais pas pourqoui, c est depuis que j'ai mise la dernier version
Top réponses
41
  • Admin
  • #7
Et tu réinstalle pas l'ancienne version ?
Moi j'ai ce bug depuis le début sur toute les versions.
marek
Membre Actif
Donateur
Top réponses
0
bonsoir pourais je voir a quoi ressemble la shoutbox siropu merci a vous
nicky1
Membre
Membre
Top réponses
0
tu as tous compris je n'avais pas mis merci laurent j ai du mal mon panel est seulement en anglais
marek
Membre Actif
Donateur
Top réponses
0
bonsoir j'ai installé la shoutbox mais je ne voit pas les smilies ni la barre avec les ajouter les images et tout les autres .
merci pour vos lumières
Top réponses
41
  • Admin
  • #19
Tu dois les activer dans les options :
Veuillez vous Identifier ou vous Inscrire pour afficher le contenu masqué.
https://lien de ton forum/admin.php?options/groups/siropuShoutbox/
