XF 2.1 / 2.2 RMS Filter by AddonsLab 1.4.0
Titre du sujet Titre du sujet RMS Filter by AddonsLab 1.4.0
Affichages Affichages 172
XenAddons RMS 2.1.10+
[AL] Core package - [AL] Core Package
Add-On Overview
The add-on allows to filter and search Review item based on Custom fields.
Review Management System add-on is developed by XenAddons. You need a valid license for it to use RMS Filter.
Here is the filter with AJAX reloading of the list in action :
The controls to filter the RMS items are added in Filters popup in the review item list :
Search Review page is also enhanced to show filter controls when the category being searched currently has custom fields associated with it :
Each field can be configured separately to be shown in the filter list and/or in the search form :
Choice fields can be configured to be shown in the forms using Check boxes and Multiple-choice drop down (allow searching/filtering by multiple values) or Drop down selection/Radio buttons (allow searching/filtering only by single value).
Date fields and numeric fields are shown as interval inputs (from... to...) where both fields are optional, so it is possible to search any values higher/lower than the defined values or in some particular interval.
Color fields are also supported and color similarity algorithm is implemented. All items with visually similar colors are found and listed. An example search listing review items filtered by color similarity can be seen here The index of color similarity is configurable and can be set from product's options page:
Text fields are searched and indexed just like review item text itself. Full-text search is executed with fuzzy matching, meaning the phrase searched does not have to be in exactly the same order as in the query.
The review item list shows all active filters. Clicking each filter will remove the field and re-run the search with the remaining filters :
The product allows moving the filters from the default location in a popup to the sidebar or above item list. The setting can be configured globally or for each category.
Xenforo Enhanced Search and Elastic Search support
The add-on has special support for Enhanced Search add-on with Elasticsearch back-end. Custom field information is indexed as a separate content type in Elasticsearch. A high-performance algorithm is implemented to filter millions of records and show only review items matching filter criteria. Custom fields are searched only once, and the result is cached for subsequent pages. Even though the product performs completely fine without Enhanced Search add-on, it is highly recommended to use this add-on and Elasticsearch on large databases.
The add-on supports faceted search and location filters. More information about this feature can be found in "Thread Filter" release notes - Thread Filter by AddonsLab - Updates
Location custom field
You are eligible for a free license of Location custom field add-on if you purchase any of our Filter add-ons.
Sortable custom field options
Our add-on at Sort Field Options for XenForo 2.x allows admins to sort custom field options when they create/edit the field in Admin Panel. The order in the admin panel affects the order in which the options are shown to the users on add/edit review item form as well as in the filters. The add-on costs $20.00 USD but it is a free module we provide with every license of RMS Filter. Feel free to contact us if you need a license and we will assign it to your account immediately.
Pricing
Add-on costs $69.99 USD that includes one year of support and updates with permanent access to product versions released in the license validity period. The yearly extension costs $40.00 USD
The add-on has a visible branding with a link to our website which can be removed for an additional $30.00 USD payment.
Trial Version
We offer seven days free trial version on our website. No credit card is required, the service is approved automatically upon registration and confirmation of the order.
IonCube Loader and PHP version 5.6+ is required to run the trial version of the product. The full version does not have such a requirement and does not have any encoded code in it.
Demo : The product is active on our forums at XenForo 2 Demo - AddonsLab and can be tested at Review Management System page.
Télécharger V1.4.0 :
