Referral System by Siropu 1.1.4
XF 2.1 / 2.2 / 2.3 Referral System by Siropu 1.1.4
Titre du sujet Titre du sujet Referral System by Siropu 1.1.4
Réponses Réponses 3
Affichages Affichages 372
Admin options
Referral URL parameter - Set a custom parameter for referral links.
Track HTTP referrer - Track the address of the page (if any) which referred the user to the referral link.
Use profile page as referral link - The user profile page will become the referral link.
Enable custom referral link generator - Allows your members to generate custom referral links from any pages.
Apply referral link to social media share icon - Social share links will become referral links.
Encrypt user ID - Replaces the user ID in the referral link with a short unique string.
Display referral count - Display the number of referrals on the user profile.
Display referrer username - Display the username of the referrer on the user profile.
Display referrals tab on member profile page - Display a referrals tab where other users can view the members referred.
Enable referral link widget - Toggle on/off a widget that will display the referral link.
Enable top referrers widget - Toggle on/off a widget that will display the top referrers.
Display invitation message to referral - A referred visitor will see a message to encourage the user to register.
Referral registration reward - A reward for each referral registration.
Referral account upgrade reward - A reward for each referral account upgrade.
The rewards work with trophy points or DB Credits add-on.
The reward amount is user group permission based and can also have a limit on how much a referrer can earn.
In ACP > Referral System you can see who referrerd who and the date. You can add or remove referrals.
You can use promo tools like banners and text links.
Télécharger V1.0.3 :
Version 1.0.4 Bug Fixes :
Error with admin option "Apply referral link to social media share icon".
Missing admin permission for managing add-on (for non super admins).
Issue when using "Encrypt user ID" showing the real user id in the cookie.
False positive duplicate account notification alerts.
Version 1.0.5 Improvements :
Added option to allow referrals to auto follow referrer upon registration. This can be enabled from admin options.
When using option "Use profile page as referral link" and visitor landed on the page from a search engine, it will not count as a referral so no cookie will be placed.
Version 1.0.6 Bug Fix : Fixed an issue with an admin template modification where rebuild cache options from other add-ons could not be applied.
Version 1.0.7 Improvements & Bug Fixes :
Added IP in referrals list in ACP linked to the list of users that might have used the same IP.
Bugs Fixed :
Referral link not applied on mobile devices to share buttons.
Referral link not applied to the post share copy link.
Télécharger V1.0.7 :
Version 1.0.8 Bug Fix : Fixed an issue with share links where referral links can result in 404 not found.
Télécharger V1.0.8 :
Version 1.0.9 : Fixed a potential error when deleting a user that was a referrer.
Version 1.1.0 : This version is compatible with XF 2.3 only.
Version 1.1.1 : Fixed a potential error on user registration with invalid IPs.
Version 1.1.2 :
Added a new option called "Enable referrer auto-follow referral" where referrer will auto-follow the referral upon registration.
Made some changes to the referral link where it is now displayed in an input field with a copy to clipboard function, for a more compact look.
Fixed an issue with the "Encrypt user ID" feature where the hashids script used is no longer compatible with PHP 8.2 or newer and it has been replaced with sqids. If you have been using this feature and running at least PHP 8.1, you have to ask your users to update their referral links because they have different IDs now.
Version 1.1.3 : Fixed an issue with potential referral link decoding error when invalid ID is provided.
Version 1.1.4 Bug Fix : Fixed an issue with missing widget info for block container.
Télécharger V1.1.4 :
Ajout de la version 1.0.7 :)
Ajout de la version 1.0.8 :)
Ajout de la version 1.1.4 :)
