The convertation is happening during the installation stage so do not install before you are ready! (see "Usage")
Since 2.2 XenForo has its own question-solution system. It means there is no need to use "Question Threads" addon.
This addon will convert all data from "Question Threads" addon to internal XenForo question-solution system.
What it does
What it does
- Converts "question only" forums to XF "question only" forums
- Converts "thread and question" forums to mixed discussion forums
- Converts question threads to XF questions
- Converts best answers to XF question solutions
- Updates "questions solved" counters
- BACKUP YOUR DATABASE (to be able to revert all changes if the process get nasty)
- Disable (not delete!) Question Threads addon
- Upgrade your forum to XenForo 2.2
- Install this converter just like other addons. Convertation will be made during installation
- Check if everything is converted well (question forums, questions, solutions and etc.)
- Remove both converter and "Question Threads" addons (including files)
- Thank you for using QT! Farewell!
