[OzzModz] Tours and Hints 2.1.7 Patch Level 1
XF 2.1 / 2.2 [OzzModz] Tours and Hints 2.1.7 Patch Level 1
Titre du sujet Titre du sujet [OzzModz] Tours and Hints 2.1.7 Patch Level 1
Affichages Affichages 145
With this add-on, you can create unlimited tours and hints on your site for any part that you want. Using its dedicated panel, you can easily manage your tours and hints separately and re order them as you wish.
Using the usergroup permissions, and user and page criteria, you can fully control where, when and to whom display the tours and hints.
Using the included Moder (dark) and Simple (light) theme, you can match the tours and hints with your style.
  • Tour and Hint title
  • Tour and Hint Message
  • Order
  • Identifier (to target the element of the page)
  • User Criteria
  • Page Criteria
  • Usergroup Permissions
  • User Preferences
Note 1 : Full XF Criteria system is supported, so you can display any tour or hint, based on the time, user, page and ...
Note 2 : 3rd party add-ons are also supported. As it is based on the page elements, it will work on any page of your XF 2.1.x site.
Permissions :
  • Can see tours
  • Can see hints
  • Can show/hide tours
  • Can show/hide hints
User account preferences :
  • Show/hide tours
  • Show/hide hints
Options :
  • Theme (Modern - Simple)
How to find element to target :
Télécharger V2.1.7 :
Version 2.1.7 Patch Level 1 : Added minified JS files.
Télécharger V2.1.7 Patch Level 1 :
    316.1 KB · Affichages: 12
    467.8 KB · Affichages: 10
    143.5 KB · Affichages: 9
    22.9 KB · Affichages: 8
    33.9 KB · Affichages: 7
    246.5 KB · Affichages: 8
    33.5 KB · Affichages: 10
Ajout de la version 2.1.7 Patch Level 1 :)
