This add-on shows how many posts and threads a user created in each sub forum. The overview table is shown in a new user profile tab named „Post Areas“. The 2.0.0 release of this add-on has exactly the same features as the 1.4.3 release for XF1.
Since 2.1.0 there is a cache feature that was integrated from Post Areas: Pro Performance. The cache is enabled by default and stores the post and thread counts of all users in a database table. This table is updated once a day by default.
Télécharger V2.1.2 :
Version 2.1.3 : Should solve the issues with not showing any posts.
Version 2.1.3 Patch Level 1 : Removed unused import from Standard Library by Xon.
Télécharger V2.1.3 Patch Level 1 :
Version 2.1.3 Patch Level 2 : Fix rerun deadlock transactions on cache rebuild.
Télécharger V2.1.3 Patch Level 2 :
- the table is sorted by post counts in descending order
- forum names are links to the corresponding forums
- post / thread counts are links to a search for all posts / threads from the user in the corresponding forum
- max number of forums shown can be set with an option
- optional cache for better performance
