[OzzModz] Advanced Sticky Thread Separator 2.0.0
XF 2.2 [OzzModz] Advanced Sticky Thread Separator 2.0.0
Titre du sujet Titre du sujet [OzzModz] Advanced Sticky Thread Separator 2.0.0
Réponses Réponses 6
Affichages Affichages 414
.jpg
Separate sticky and normal threads with labeled headers, or a divider bar. Comes with settings and style properties to customize the appearance with your Xenforo theme. The goal is to create the most powerful sticky thread separator addon, which leaves nothing out.
If you have suggestions for making this addon better, please leave a comment
Supports Xenforo 2.2's Article Forum Layout !
  • Enable/disable for each style
  • Select between labeled headers, or a divider bar
  • Show a pin icon next to the Sticky Threads label (optional)
  • Fully phrased - change labels using Xenforo Phrase system
  • Style Properties to control appearance
  • Works with Xenforo 2.2's article node type and grid/expanded layouts
  • Works with all Nulumia themes, including pro features such as Discussion Grid
Labeled headers :
.jpg
Divider bar :
.jpg
Customize sticky threads with style properties :
.jpg
Works with Xenforo's Article Forum layout :
.jpg
Advanced conditionals to even work with the Nulumia Discussion Grid :
.jpg
Télécharger V1.0.0.3 :
Version 2.0.0 :
- Initial release under OzzModz.
- Changed name, developer info and links to reflect OzzModz.
    .jpg
    72.2 KB · Affichages: 12
    .jpg
    68.7 KB · Affichages: 13
Ajout de la version 2.0.0 :)
J'ai hâte de tester cette nouveauté, merci Laurent.
