Want to know which OS and Browser your members are using in XenForo 2?
Then this add-on is for you!
OS/Browser Display shows which OS and Browser your members are using in posts and PCs.*
*Information shows for new posts only. There is no way to go back and retrieve the information for old posts.
Télécharger V2.0.6 :
Version 2.0.7 change :
Fixed: ErrorException: Fatal Error: Access level to SV\ConversationEssentials\XF\Service\Conversation\Creator::_save() must be public (as in class Snog\OSBrowser\XF\Service\Conversation\Creator) src/addons/SV/ConversationEssentials/XF/Service/Conversation/Creator.php:15
Version 2.0.8 change :
Added: Support added for, Basilisk, Brave and Avast.
Added: Missing phrase in changelog.
Version 2.0.9 change :
Fixed: Image issues with the 2.0.8 update.
Fixed: Typo for the Yandex browser.
Fixed: The Edge logo from Edge version 79 forward, the old logo is still used for any version less than 79.
Version 2.0.10 change :
Fixed: post_macros template modification to hopefully be more compatible with all styles.
Changed: Addon name to [OzzModz] OS/Browser Display
Added: Support link for addon in the addon list in the ACP.
Version 2.0.11 change : Fixed: Error XF\Service\Conversation\Creator::_save() must be public.
Télécharger V2.0.11 :
Version 2.0.12 Changelog :
Version 2.0.13 : Fixed template modification that was not showing the checkbox in user privacy options.
Télécharger V2.0.13 :
Version 2.1.0 change : XF 2.2 and 2.3 compatibility
Télécharger V2.1.0 :
- Set who can view OS/Browser info by usergroup.
- Display OS/Browser as icons only.
- Display OS/Browser as icons and text.
- Display OS/Browser as text only.
- Uses sprites to limit http requests.
- Each post/PC shows the OS/Browser the user was using at the moment that post/PC was made.
- Minor code refactor & cleanup
- Moved entity structure modifiers to code event listeners to avoid broken extension chain errors
- Properly handle external data path for INI file
