[MR] Copying Content 2.0.1 Patch Level 1
XF 2.1 [MR] Copying Content 2.0.1 Patch Level 1
Titre du sujet Titre du sujet [MR] Copying Content 2.0.1 Patch Level 1
Affichages Affichages 238
Dernier message par Dernier message par Napolion
The addition provides simple protection against copy-paste (If desired, everything can be copied).
Main features :
  • Adding a link to the source to the copied text
  • Alert when text is copied
  • Disable right key press
  • Prevent text selection
  • Prohibition of copying text
Distinctive features :
  • The text of the fields can be changed both in the field and in phrases, which allows convenient use on multilingual forums
  • If you have a multilingual forum, then you can adjust the text in the phrases: mr_copying_content_textbox_default and mr_copying_content_textarea_default
  • There are also group rights
  • Excluding work in certain sections
