L'add-on donne un contrôle total sur les liens que vous avez dans tous vos messages, vous permettant de les rechercher rapidement, de vérifier leur statut, de les modifier un à un ou à la fois. La prise en charge d’autres types de contenu (ressources, publications de profil, blog tiers, additifs d’article, etc.) sera publiée en tant que plug-ins payants distincts. Veuillez consulter la section des modules associés pour plus d'informations.
Les balises BB Code prises en charge sont URL, MEDIA et IMG. Les types de supports pris en charge sont YouTube, DailyMotion et Vimeo. D'autres types de média peuvent être pris en charge si nécessaire.
The product comes with the following main features and pages :
We are getting reports from our customers, that several URLs are actually alive but the product does not recognize it and gives an error when trying to save the URL in Admin Panel.
It is important to realize, that checking a URL automatically is not the same as visiting the URL in your browsers. There are many techniques available, that can make a page to work when visiting by the browser, or when Google indexes the site, but block any other bots, including our bot that checks the status of URL.
Feel free to contact us whenever you get any URL that doesn't work for you in our add-on but works via browser, but so far in all cases, we had this resulted from the site/IP being blocked by another site or automated requests being blocked altogether. Please consider adding the URL/Domain to the exclusion list in these cases.
Disclaimer: Please make sure to backup your database before using the tool. It is processing the real content of the database and any changes committed are impossible to revert.
Planned Features :
- A new section in Admin Panel, under Tools section, allowing you control the product.
- Rebuild page to find all links posted on your board currently. A separate rebuild task can be run to check the status of the links.
- Manage Links page lists all links found so far. It has a quick search and filter controls allowing you to quickly find links by URL.
- Each link can be edited individually. Edit page gives full information about last status check, allows to force-update the status by checking it one more time, to set the URL and text of the link or to delete it. It also has a link to the content where the URL was used so you can check the post quickly if needed.
- Deletion of links allows setting a placeholder message that will replace the link. It can be left empty for the simple removal of the link.
- Advanced batch update tool allows you to change an unlimited number of URLs at once. Caution: use the tool with care as it modifies the database content, and any submitted changes will not be reversible.
- Batch update page allows to quickly find any link by its status code, the content of the URL or its text, URL domain etc. Replacement options are to replace the URL/text entirely, or to do partial replacement only replacing the parts defined in your search criteria. The tag can also be deleted or the content having the tag in it (post, thread) can be deleted entirely.
- Regular expressions are supported in both search and replace mode. Subpatterns of matched searched criteria can be used as variables in the replacement.
- Live preview of all changes, which will be saved to the database.
- Ability to process only sevaral of tags using the checkboxes in the preview.
- A link can be shown under each post allowing to force-update the status of all links found in the post. Controllable by a new usergroup permission.
- Moderation queue support. Invalid links are added to the queue where forum moderators can see the links detected in their forums and modify/delete them. Their actions are logged in Moderator Log. The permission should be enabled on per-usergroup basis.
- Alert users about their link not being valid. The permission should be set on per-usergroup basis. The alert is automatically removed if the URL is validated later.
- Links in the posts can have a "valid" or an "invalid" icon next to the link based on their status. The usergroups allowed to see the icons are controlled via XenForo Usergroup Permissions page.
- The "valid" icon can be hidden for all usergroups at once if you prefer not to have it but to show broken links only.
- Special support for "429 Too Many Requests" URLs. If a server blocks the requests because they are too often, the validation is scheduled and run with some delay.
- Batch Update and Dead Link Check can run both in the browser and as a cron job in background. In that case, admins can see the status of the background tasks on that pages.
Planned Features :
- Front-end management of broken links by users who posted them.
Question: Are there any steps to follow after the first installation?
Answer:
Question: Does the add-on handle properly the URLs containing Unicode characters?
Answer:
For all admins working on boards using Unicode and other non-URL compatible characters in URLs we would like to stress the importance of understanding, how URLs containing special characters work. URLs themselves are not allowed to have Unicode/special characters. All Unicode characters are converted to their compatible version (URL encoding). You can confirm this by editing any post, which has a Unicode-containing link and see the source code. And you will see the link does not contain Unicode characters and is fully encoded. Basically, our product just takes the URLs from the post and processes them just as they are in the text. If a user follows the URL, browsers show the text in Unicode characters, but this does not mean, that the URL actually has this characters inside. We have decided, however, to avoid confusion for admins, to show decoded characters on the list and Batch Update page. When you are editing a link, however, we will show the real URL, and any URL you paste as a replacement should be properly encoded. You should not try to type Unicode characters in the field directly, but rather copy the link from a browser, which will automatically do the conversion for you.
Here is the list of processes, where we do URL encoding conversion:
Question: What is the User Agent option and how should I use it?
Answer:
User Agent is a string identifier, that identifies your board for the remote sites, for them to know "who" makes the request. By default, the "User Agent" contains your board URL. In some cases, this identifier is used on remote sites to block your website from making further requests to them. You can change the user agent used in this option, but you should do so at your own risk, as changing of the user agent to overcome site access limitations may be illegal in some cases. User agent format is usually ProductName/number.number (any comment here).
Question: Why I see Timeout status on some links sometimes, and the same links work in another case?
Answer: Timeout status means, that the request to check link's validity timed out, meaning the remote server did not reply in time. This can happen, when, for example, the remote server is down for some time. It also can be due to the fact, that links are checked "quickly" when the user posts them, with 0.5-second timeout, but the links are scheduled for more thorough check, with 5 seconds timeout, via a deferred task. So, you may see a link as invalid right after posting, but after some time, if the link is valid, it will turn to valid status.
Some remote servers prefer not to send 403 Forbidden error when the access to some resource is denied (e.g. you IP is blocked on their server), but to block the request by keeping it open long time and eventually timing out. In this case you will get permanent timeout status even if you re-check the link.
Rebuild Data admin page also allows to manually set the number of seconds for a request to timeout. If you see too many timeout errors, you should consider to increase this limit. We have also implemented the option to check only timed-out links, so we would recommend to check all your links with normal timeout limit (1 second), and only after that check the links that timed-out with higher timeout limit (e.g. 5 seconds).
Please note, that timeout error is a connectivity issue and not a bug in the product, and if the same link times out one time and not another time with all other conditions being equal, that does not mean the product works differently each time, but that the link is available for not at that moment.
Question: Why I see some URLs as valid, but visiting them I see they dead/not found?
Answer: The product depends on information provided by the remote server in page headers when checking the status of a link. In the case described, that means the server returns an error page to users, but in headers it actually returns a success code.
Answer:
- Setup the permissions of who can see link status in posts - Usergroups -> [Choose the usergroup] -> Link Checker
- Trigger full indexation of all existing links - Tools -> Links -> Rebuild Data ->
- Check the status of all links using the "Check Dead Links" tool on the same page. This tool sends requests to each URL to identify if they are broken or no. It will take a long time to execute, especially with many links and if many of them are broken or are pointing to slow servers.
- Once the task above is completed you will be able to see the list of links, filter them by status and apply batch modification actions from Batch Update page. For the list of all links with the ability to edit each of them use Manage Tags page.
- Check product settings at Setup -> Options -> Link Checker by AddonsLab
Answer:
- In Manage Links page, you will see the Unicode characters inside URLs.
- When editing a link, you will see the Unicode characters in Full Code sector but will see the encoded version in the field to edit the URL.
- On Batch update page, Search Link URL content will be automatically URL-encoded before the search. So the text you type there can be in Unicode or contain special characters, they will be converted to URL format on the fly.
- Process URL field content will be transformed into URL-encoded version only if you use "Replace found part" mode. So, if using "Replace found part" mode, you should use Unicode characters in both search and replacement field. However, if you are using "Replace Fully" mode, the URL you will use in the field should be fully valid, meaning all Unicode characters should be already converted to URL-compatible version.
- Regular expression matching is done after the search term is URL-encoded.
- Subpattern replacement is done before the replacement term is converted to URL-encoded version.
- In replacement preview, you will see the Unicode characters, but in actual replacement will use valid URL-encoded strings.
Answer:
