[Liam W.] Post Macros 5.3.0 Fix 4
XF 2.1 / 2.2 / 2.3 [Liam W.] Post Macros 5.3.0 Fix 4
Titre du sujet Titre du sujet [Liam W.] Post Macros 5.3.0 Fix 4
Réponses Réponses 32
Affichages Affichages 2 076
Réaction Réaction 3
Dernier message par Dernier message par Okaki
  • Post Macros 5 is a XenForo 2 compatible major rewrite of my Post Macros add-on for XF 1.
  • Post Macros allows your users to define 'macros' that are available to use inside of the rich text editors on your board. These macros can have 'metadata' assigned to them, allowing them to perform actions such as setting the thread title when creating a new thread, or setting the thread prefix or lock/unlock state.
  • Macros can also be shared between users - although users must first 'enrol' onto them, so as to prevent a large buildup of unwanted macros on the editor list.
  • Board administrators can also create 'Global macros', that are defined via the admin control panel, and available to users' with the relevant permissions - permissions for global macros use the standard XF permissions system, so fully support permission inheritance.
  • This add-on is under the MIT license.
Feature summary :
  • Options : //TODO
Branding :
  • This add-on does not include branding.
Installation :
  • Download and unzip it.
  • Copy the src/addons/LiamW/PostMacros directory to your server.
  • From the AdminCP install the add-on.
Note :
Télécharger V5.1.3 :
Version 5.1.4 Changed :
Fixed a version mismatch. (@Sunka #Report)
Fixed a bug with a shared macro, you can not enroll it. (@SeToY #Report)
Télécharger V5.1.4 :
Version 5.1.5 Changed : N/A
Added : A macro can be posted as another user (@DragonByte Tech #Report)
Télécharger V5.1.5 :
Version 5.1.6 Added :
Auto submit for global macros (@Coderax #Suggestion)
Auto move to sub-forum after post (@Coderax #Suggestion)
Version 5.1.6 Fix 1 Changed : During the 5.1.6 update, the column : change_category was not installed. (@Coderax #Report)
Version 5.1.6 Fix 2 Changed : After auto-submitting, it doesn't move. (@Coderax #Report)
Version 5.1.6 Fix 3 Changed : Call to undefined method XF\Mvc\Reply\Error::getParam(). (@sevenmix #Report)
Télécharger V5.1.6 Fix 3 :
Update 5.1.6 Fix 4 Changed :
Error: Call to a member function last() on array in src/addons/LiamW/PostMacros/XF/Pub/Controller/Thread.php at line 20 (@imno007 #Report)
Télécharger V5.1.6 Fix 4 :
Version 5.2.0 Changed :
When use autosubmit it trow an error and do nothing. (@malachiel #Report)
Note : This version of the add-on is now compatible with the version 2.2.0 Beta 1 and higher of XenForo.
Version 5.2.0 Fix 1 Changed : Missing files. (@Rhodium)
Télécharger V5.2.0 Fix 1 :
Version 5.2.0 Fix 2 Changed :
Bug when using two placeholders. (@SeToY #Report #2)
When the same placeholder is used twice, it will display 2 useless fields (@SeToY #Report #3)
Télécharger V5.2.0 Fix 2 :
Version 5.2.0 Fix 3 Changed : Missing JS files.
Télécharger V5.2.0 Fix 3 :
Version 5.2.1 Added : Now you can add FA icons to post macros for the editor dropdown.
Version 5.2.1 Fix 1 Changed : Thread title was not applied.
Télécharger V5.2.1 Fix 1 :
Version 5.2.1 Fix 2 Changed : Conversation title not applied anymore after upgrading to 5.2.1 Fix 1.
Télécharger V5.2.1 Fix 2 :
Version 5.2.1 Fix 3 :
Changed : Problem in the macro with auto insert for prefix. (@Iggy #Report)
Added : Phrase request. (@Iggy #Suggestion)
Version 5.2.1 Fix 4 Changed : Error in a template modification. (@swiftyste #Report)
Télécharger V5.2.1 Fix 4 :
Version 5.2.2 Added :
  • Add a rebuild permission system (in rebuild cache), this should avoid the message that appears in the admin panel.
    If you're modifying post macro permissions for a user group or changing a global macro, please rebuild
  • Add a permission for the metadata thread
Télécharger V5.2.2:
Update 5.2.2 Fix 2​
Changed :
  • After the 5.2.2 update, users no longer had access to their macro.
Télécharger V5.2.2 Fix 2:
Update 5.2.2 Fix 3​
Changed :
  • After update 5.2.2, users can no longer see their macro in the editor.
Télécharger V5.2.2 Fix 3:
Version 5.2.2 Fix 4 update:​
Changed :
  • Pagination in active macro does not work. (@Ivancas #Report)
Télécharger V5.2.2 Fix 4 :
Version 5.2.2 Fix 5 update:​
Changed :
  • There is no permission option for thread metadata section.
Télécharger V5.2.2 Fix 5 :
Version 5.2.2 Fix 6 update:​
Changed :
  • Error: Macro public:liamw_postmacros_macro_list_macros :: liamw_postmacros_macro_list_block() error: Call to a member function canUse() on nul (@sevenmix #Report)
Télécharger V5.2.2 Fix 6 :
Version 5.2.2 Fix 7 update:​
Changed :
  • There are more metadata options in the global post macro in the ACP (@pec #Report)
Télécharger V5.2.2 Fix 7 :
Version 5.2.2 Fix 8 Changed :
  • The "Expand macros in macro list by default" is always displayed in the setting, even if disabled. (@pec #Report)
Télécharger V5.2.2 Fix 8 :
Version 5.3.0 :
Changed :
- Code cleaned.
Note :
- This version of the add-on is now compatible with the version 2.3.0+ of XenForo.
- This version of the add-on now require PHP 8.0+.
Télécharger V5.3.0 :
Version 5.3.0 Fix 1 Changed :
- Macro public:liamw_postmacros_iconpicker_macros:liamw_postmacros_icon_picker is unknown.
Télécharger V5.3.0 Fix 1 :
Version 5.3.0 Fix 2 Changed :
- Missing phrases
- This version is only compatible with XF2.3
Télécharger V5.3.0 Fix 2 :
Version 5.3.0 Fix 3 Changed :
The macro is not in the right place
Télécharger V5.3.0 Fix 3 :
Version 5.3.0 Fix 4 Changed : When we put 0 in the placeholders, the output in the message shows nothing, instead of showing 0.
Télécharger V5.3.0 Fix 4 :
XF 2.1 / 2.2 / 2.3  Private Site 1.2.0
XF 2.1 / 2.2 / 2.3  Approval Queue Plus 3.5.2
    240.2 KB · Affichages: 88
    238.4 KB · Affichages: 63
    232.4 KB · Affichages: 63
    69.3 KB · Affichages: 63
    281 KB · Affichages: 62
    206.6 KB · Affichages: 57
    215.9 KB · Affichages: 58
    287.7 KB · Affichages: 56
