[Liam W.] Conversation Folders 2.2.0 Fix 1
XF 2.1 / 2.2 / 2.3 [Liam W.] Conversation Folders 2.2.0 Fix 1
Titre du sujet Titre du sujet [Liam W.] Conversation Folders 2.2.0 Fix 1
Réponses Réponses 17
Affichages Affichages 1 057
  • Sort your conversations into named folders with Conversation Folders. Users can create folders and file their conversations into them.
  • Independent folders per conversation recipient
  • Conversation counts displayed next to folder name
  • Move conversations to folders using the conversation inline moderation system
  • Auto-file conversations into folder(s) as they're received, using a substring or regular expression match
  • This add-on is under the MIT license.
Feature summary :
  • Options : //TODO
Branding :
  • This add-on does not include branding.
Installation :
  • Download and unzip it.
  • Copy the src/addons/LiamW/ConversationFolders directory to your server.
  • From the AdminCP install the add-on.
Télécharger V2.0.1 :
Version 2.0.1 Fix 1 Changed :
There's a sentence missing when editing a folder ( #Report)
Error when moving a conversation (#Report)
Added : N/A
Removed : N/A
Note : N/A
Télécharger V2.0.1 Fix 1 :
Version 2.0.2 Fix 2 Change log :
Bug fixes :
You can no longer edit a folder if you have exceeded the folder creation limit.
Update 2.0.2 Fix 1 Changed : If we put 5 in the folder limit, the user could create 6 folders.
Télécharger V2.0.2 Fix 2 :
Version 2.0.3 Changed : Added Folder Order/Sorting. (#Suggestion)
Télécharger V2.0.3 :
Version 2.0.4 : Added the possibility to use filters in folders.
Version 2.0.4 fix 1 changed : Forget about a template modification for the last update (2.0.4)
Télécharger V2.0.4 fix 1 :
Version 2.1.0 change :
Added
: Add-on now compatible with account upgrades. (@tommyxv #Suggestion)
Note : This version of the add-on is now compatible with the version 2.2.0 Beta 1 and higher of XenForo.
Télécharger V2.1.0 :
Version 2.1.1 Fix 1 Changed :
Add-on now working with the version 2.2.6 Patch 2.
Now you can select the folder when you create a conversation. (@tommyxv)
Télécharger V2.1.1 Fix 1 :
Version 2.1.1 Fix 2 Changed : Folders file convo not working. (@tommyxv #Report).
Télécharger V2.1.1 Fix 2 :
Version 2.2.0 :
- Changed :Code cleaned.
Note :
- This version of the add-on is now compatible with the version 2.3.0+ of XenForo.
- This version of the add-on now require PHP 8.0+.
Télécharger V2.2.0 :
Version 2.2.0 Fix 1 Changed : We can no longer move conversations in different folders.
Télécharger V2.2.0 Fix 1 :
    65.6 KB · Affichages: 13
    112.6 KB · Affichages: 12
    56.4 KB · Affichages: 13
    78.8 KB · Affichages: 12
Ajout de la version 2.0.1 Fix 1 :)
Ajout de la version 2.0.2 Fix 2 :)
Ajout de la version 2.0.3 :)
Ajout de la version 2.0.4 fix 1 :)
Ajout de la version 2.1.0 :)
Ajout de la version 2.1.1 Fix 1 :)
Ajout de la version 2.1.1 Fix 2 :)
Merci pour la mise à jour
Le passage en 2.3 se précise de plus en plus, une fois tous les addons à jour
