Learn how to install our styles properly Xenforo 2
Installation:
Few key points:
Installation:
- Download your style here (you may need to activate your license first) and extract the zip
- Upload contents of the /upload/styles/ folder to your /styles/ folder by using your FTP or control panel
- Go to your control panel, Appearance -> Styles -> Import, import the style found inside your XML folder
- Now click the + Add style button and fill in as followed:
- Title: Name Your Style
- .Description: Give a brief description of the style (optional)
- Important! Parent style: Set the style you imported on step 3 as the parent style
- You can set the style to the default forum style by choosing the radio button (highlighted in red below)
Few key points:
- Do not make edits inside the main style (the one that says (Parent DO NOT EDIT)
- Any edits you want to make should go inside your child style, in the above example "My Style"
- You will lose all customizations on upgrade if you customize the style that says (Parent DO NOT EDIT)
