Compatible XF versions 2.2
Editor & BB Code Manager
Description
Fully customize your XenForo Froala instance. Change your toolbar layout, enable and disable BB Codes, make use of the new table and background-color BB Codes, provide exciting new fonts for your users from your own server or external hosts. It's all in your hands.
Please note: The license of this add-on does not entitle you to use this add-on on a commercially active XenForo installation, meaning that when you run some form of commercial income on your XenForo installation (ads, user upgrades or other means of money generation), you are required to extend your license to a commercial license. Commercial licenses are a one-time payment and includes all future updates. You are required to buy one license per online accessible XenForo installation that is commercially active. Commercial licenses for this add-on are available at a price of 60€/each. Be fair and keep this add-on free for everyone who offers his content for free.
Features
BB Codes
Installation
Changelog
Important Notes
Bugfixes & Changes
Télécharger V2.0.0 Beta 2 :
Version V2.0.0 Release Candidate 1
Changelog
Important Notes
Version V2.0.0 Release Candidate 2
Télécharger V2.0.0 Candidate 2 :
Version 2.0.0 Changelog
Important Notes
Version 2.0.1 Changelog :
Important Notes
Version 2.0.1 Patch Level 1Changelog :
Important Notes
Telecharger V2.0.1 Patch level 1 :
Fix pour xenforo 2.3 :
Télécharger Fix :
Description
Features
BB Codes
- Enable & disable all BB codes on the fly
- Control access to all BB codes via user criteria
- Create aliases for your BB codes
- New BB codes:
- Superscript & Subscript
- Background color
- ParseHtml
- Hide BB Codes
- Align: Justify
- Customize:
- Available fonts for the font BB code
- Available sizes for the size BB code
- Control smilie access with criteria
- Font awesome BB code
- Lazy load mode to speed up page load time
- Manage your font list
- Easily include fonts hosted on your own server or from Google Fonts
- Allow users to use all available Google Fonts and load them on demand
- Use public and private post templates to quickly insert content into your editor.
- Character/letter counter
- Special Character dropdown for easy special character insertion
- Post Templates, for quickly inserting reusable editor content
Installation
- Upload the content of the upload-folder to your XenForo root directory.
- Head to ACP -> Add-Ons and install the Editor Manager
- Configure your addon under ACP -> Content -> Editor Manager
- Read the patch notes for potential additional necessary steps!
- Upload the content if the upload-folder to your XenForo root directory. Overwrite files when asked.
- Head to ACP -> Add-Ons and upgrade the Editor Manager
- Head to ACP -> Add-Ons and uninstall the Editor Manager
- Delete the following folders inside your XenForo root directory:
- js/editor-manager/
- data/fonts/
- src/addons/KL/EditorManager/
- styles/fonts/editor-manager/
Changelog
Important Notes
- This is a beta release, bugs are to be expected, and timely fixes are not guaranteed
- Do not upgrade any live site with this yet
- Added new [fa] BB code to display font awesome icons
- Added BB code option to hide all links to guests
- Added page criteria to public editor template conditions
- Added new Hide BB codes
- Hide unless in user group
- Hide to unregistered visitors
- Hide until timestamp
- Added XenForo caching support
- Added smilie criteria to control which users can use some smilies
[/fa]
Bugfixes & Changes
- Resolved an error when attempting to save a user profile entity
- Resolved an error that prevented saving empty entity sets to the cache
- Resolved an edge-case error with addon.json files that do not include a title attribute
Changelog
Important Notes
- This is a release candidate release, bugs are likely, and timely fixes are not guaranteed
- Before upgrading your live site, perform a test upgrade on an up-to-date clone of it!
- Resolved an issue that caused the installer to get stuck when a previous installation was interrupted
- Resolved an issue that would cause the 1.2+ > 2.0+ update step to be interrupted
- Resolved an issue that would prevent the Editor Config cache from saving properly
- Resolved an issue that would list database columns as missing when they weren't
Changelog
Important Notes
Bugfixes & Changes
- Resolved an issue that caused the installer to throw warnings when a previous installation was interrupted
- Resolved an issue that would throw templater warnings on various occassions
- Resolved an issue that would show a blank editor template dropdown when no editor templates were available (the button is now correctly hidden instead)
- Resolved an issue that would not remove public templates from view when they were disabled in the ACP
- Resolved an issue that would not remove public templates from view when page criteria weren't met
- Resolved an issue that would prevent page criteria for public templates from being saved
- Resolved a templater error that would appear when a user accessed their account preferences while editor word count mode was set to user selectable
- Resolved an issue that would prevent the installer from correctly removing all tables and columns added by this add-on (most tables and columns were still removed)
- Updated the installer to purge all Editor Config caches on update
Important Notes
- Resolved an issue that would prevent user criteria to apply to BB codes that were used via aliases
- Resolved an issue that would prevent editor buttons to show up in the toolbar preview if the viewing user could not use them
- Resolved an issue that would prevent the public editor template cache from updating when a template was deleted
Important Notes
- Fixed Google fonts not loading when multiple fonts were being requested
- Fixed editor configuration not being loaded on ACP editors
- Fixed editor templates on frontend not being sortable due to error
- Fixed lazy loading preventing editor toolbars in the ACP from being edited
- Fixed BB Code permissions preventing BB Code buttons from being added to toolbar layouts
- Fixed BB Code aliases not working in some instances
Important Notes
- Fix HIDE BB Codes being displayed to all guests, if content was posted by a guest user.
- Fix PHP 8.4 related errors.
Télécharger Fix :
06VGUlu.png61.9 KB · Affichages: 99 -
apHMzZh.png100.8 KB · Affichages: 93 -
CarefulUnkemptDwarfrabbit.gif2.2 MB · Affichages: 106 -
d6Y35ap.png137.4 KB · Affichages: 100 -
EnchantingAllAffenpinscher.gif1.5 MB · Affichages: 112 -
EQXGNtU.png101.9 KB · Affichages: 90 -
PVctL8Q.png63.2 KB · Affichages: 72 -
qG7EXBP.png80.2 KB · Affichages: 74 -
uBfO1oC.png61.6 KB · Affichages: 94
sais ma facon de penser sur ce bonne soiree et bonnes fetes de fin d annee a toutes et tous
