Description:
Move default navigation to the left forum side and show it vertically with some extra features.
Check DEMO on our forum
Screens :
< extended style - main navigation with subnavigation in vertical position >
< condensed style - only main navigation in a vertical position, subnavigation is in horizontal navigation >
< with some options enabled >
Version 1.0.1 : bugfix: the CSS for vertical navigation is now grabbed from default navigation.
Version 1.0.2 : minor CSS changes.
Version 1.0.3 bugfix : the Cookies link in the default footer is now visible when Show footer option is enabled.
Version 1.1.0 :
Version 1.1.1 : Compatibility fix for XenForo 2.3
Version 1.1.2 : Bugfix for direct message phrase (for XF 2.3).
Télécharger V1.1.2 :
- option to enable vertical navigation per style in style properties
- note that vertical navigation will show only on bigger screens (more than wide responsive break point)
- set the width of the column where vertical navigation is
- extended style option = main navigation with subnavigation in vertical position
- condensed style option = only main navigation in a vertical position, subnavigation is in horizontal navigation (where the default XenForo navigation is otherwise)
- set the logo size and position (left or center)
- two widget positions in vertical navigation (top and bottom)
- show New posts button right below the logo
- show visitor tabs (account | conversations | alerts) in vertical navigation. Note: this will hide visitor tabs from the default navigation
- show footer (fixed) in vertical navigation with style and language chooser links. Note: this will remove mentioned links from the default footer
- show forum header if you use the header advertisement position or features from [cXF] Widget Homepage add-on. By default, the header is hidden with this add-on
- show full or default forum page width
- option to style the vertical navigation content (background etc.)
Screens :
Version 1.1.0 :
- bugfix: Style and Language links in footer didn't show right
- added support for DragonByte eCommerce Cart link in navigation (note: by default this template modification is disabled. To enable it, go to Appearance > Template modifications in the Admin section. Under [cXF] Vertical Navigation find
cxf_vertical_navigation - Add DragonByte eCommerce Cart link
