[cXF] Customize ads after first post 1.0.0
Xenforo 2.x.x [cXF] Customize ads after first post 1.0.0
Titre du sujet Titre du sujet [cXF] Customize ads after first post 1.0.0
Affichages Affichages 324
You can easily customize your ads (for example AdSense) by adding some extra code to your HTML box when creating your ad.
Example #1 :
... and on mobile :
As you can see in above screen the ad will show like post with avatar. The title below avatar is phrased so check for cxf_ads_after_first_postphrase to edit it.
Use this code for above result :
Add your ad code by replacing the <!-- AD CODE HERE -->
Example #2 :
If you don't want to use your ads with avatar like it's shown in previous example you can still wrap them in a nice block by adding this simple code :
