[CinVin] Emoji Tweaks (use SVG images for emoji instead of PNG) 1.2.0
XF 2.2 / 2.3 [CinVin] Emoji Tweaks (use SVG images for emoji instead of PNG) 1.2.0
Titre du sujet Titre du sujet [CinVin] Emoji Tweaks (use SVG images for emoji instead of PNG) 1.2.0
Affichages Affichages 200
Your XenForo 'Emoji Source' must be set to "Host from following location" with a valid value. This will not work if you use the default "Serve from preferred CDN" setting.
This is a small add-on that will change the file extension of emoji images when served from a custom CDN. For our sites we serve the emoji images from our own locations and use .SVG images.
Read the FAQ for an example of how to use Twitter's Twemoji .SVG images for your emoji.
Version 1.2.0 XF 2.3.0 Update :
- Updated for XF 2.3.0 compatibility, there are no other changes in this release.
Ajout de la version 1.2.0 :)
