.detection methods :
Permissions :
Reports :
Télécharger V1.3.1a :
Version 1.3.2 fixed : The links of the tabs in the member profile were incorrect
Télécharger V1.3.2 :
Version 1.3.3 - Important update :
FIX : Multiccount could be falsified by assigning an account to another user
Télécharger V1.3.3 :
Version 1.4.0 Changes :
Added FingerprintJS Pro support
FingerprintJS updated to 3.2.0
Reports page was reworked
Added pagination
Added fast inline moderation
Added reason for closure
Note :
Before this update, it is advisable to remove these directories :
Télécharger V1.4.0 :
Version 1.7.1 : Added check for full unicode support during installation to prevent server errors.
Télécharger V1.7.1 :
Version 1.7.2 : Updated JS dependencies.
Télécharger V1.7.2 :
- Fingerprintjs (~70%)
- Evercookie (100%)
Permissions :
Reports :
Added pagination
Note :
mucacho
js/bs/mad
Version 1.4.1 Changes :
- Updated dependencies
- Now only one request is executed when checking instead of two or more
- Fixed a bug due to which a duplicate report could be created
Version 1.5.0 New features :
– New option: Display link to reports regardless of the open reports presence
– New option: Create a separate report if a new multi-account is detected
Fixes
– Problem with compatibility of XF scripts in some places (conversations, user ban)
– Reduced number of scripts to load. Previously, scripts for all detection methods were loaded for the user, but now they are loaded depending on the activated detection methods
Version 1.5.1 Fixed :
- Incorrect work of the Evercookies method
- Possible duplicate usernames in reports in the Fingerprint section
Version 1.5.2 : Updated Fingerprintjs and other dependencies
Version 1.5.3 Changes :
- New option "Thread report duplicate creator".
- If you had problems with creating reports in a forum - fill in this option.
- Now problems with creating a report in a forum will not affect the creation of regular reports
This update will create all reports that were not created due to an error creating a duplicate report in a forum
Version 1.5.4 Fixed : [021] Multi-account detector [Paid]
Version 1.6.0 :
- Added "Сheck
down" option
- Check
down now resets when user logging in
Version 1.7.0 New options :
- Fingerprint detected user group – this group will be automatically assigned to the user if he falls under the definition of a multi-account using the fingerprint method.
- Evercookie detected user group – this group will be automatically assigned to the user if he falls under the definition of a multi-account using the evercookie method.
– Creating a duplicate report in the specified forumLet's imagine the situation: User Bobby already has a report on a multi-account, which contains his other account with the nickname George, and he logs into a new account with the nickname Henryk. If this option is enabled, a new report will be created for the Henryk account, which will list the previous two accounts: Bobby and George. If this option is disabled, Henryk's account will be added to the first report on Bobby's account. However, if this report is closed, you will not receive a new notification.
Fixes
Version 1.6.0 :
- Added "Сheck
- Check
