This addon creates a live forum statistics widget to keep your users updated and engaged. The data it displays is current and can be refreshed at anytime, it includes user and thread statistics as well as a list of new threads.
In addition to being a statistic widget, it enables you to sell "Pinned" records to monetize your forum. Using this addon you can sell links to user threads and offsite links inside the widget.
If you are looking for other methods to monetize your forum please see our Thread Up addon.
Widget Display :
Thread tab example configuration :
Members tab example configuration :
Sticked links/threads sales :
Public store :
All links must be approved and then user will receive alert what he can pay link :
Paid sticked attributes :
You can add any attribute making it both paid and free. If the attribute is paid, then when purchasing a fastener, if the user fills it in, the cost of the attribute is added to the price of the fastener.
There are two types of attribute: style and another. All style type attributes will be written to the style attribute. For example, a pinned link with the color attribute, after the purchase will have this attribute: style="color:red;".
An attribute of type another will be added as {key}="{value}"
Customize the tab for yourself :
User permissions :
Télécharger V1.0.9 :
Version 1.1.0 change :
New Member definition options
User is a member of any of these groups
User is NOT a member of any of these groups
New style properties
Enable second data display for thread items
Saving tab title: If the developer mode is turned off, the contents of the phrase in the visitor’s language, and not in the master language, will be changed
A warning was added when filling in the field "add-on"
Store page is no longer available for guests
Scrolling content loading added
Added update animation when clicking on the statistics update button
Version 1.1.0 Patch 1 change : Incorrect record limitation for the
Version 1.1.0 Patch 2 change : Added compatibility with older versions of AMS
Version 1.1.0 Patch 3 change :
fixed : Cannot call method canReport on a non-object (NULL) when a thread has no first post
Télécharger V1.1.0 Patch 3 :
Version 1.1.0 Patch 4 fixed : Added receipt templates for emails
Télécharger V1.1.0 Patch 4 :
Version 1.1.1 changes :
New widget options
Enable scroll pagination
Pagination depending on the position of the window scroll
Load the a next page contents when X percent of a window is scrolled
Fixed :
Added link pin payment receipt email template
When switching from a tab in which there is pagination to a tab in which there is no pagination, loading was performed from the first tab
Incorrect values for date cut off
Version 1.2.0 Changes : Ability to stop ignoring all ignored threads in statistics (Find threads -> Ignored threads in statistics)
Thread definition changes :
New order by : Vote score
Thread type filter
New "Quantitative сriteria" options: filters by views, replies, vote score
Member definitions changes : The ability to sort users by several criteria
Fixed : Now links in the "Latest posts" tab will lead to the last message (only if a thread has been read)
To upgrade to this version, you must have XF 2.2+ and PHP 7.4+
Version 1.2.1 Fixed : [BS] Live forum statistics
Version 1.3.0 :
Removed the "Fetch content after page load" option – this is now the default behavior.
Support for the Keep Alive XenForo system that updates the CSRF token when a tab is restored in browsers on mobile devices. This will get rid of such errors: Cookie Required To Use This Site, Security Error.
Télécharger V1.3.0 :
Widget Display :
- New Members, New Messages
- Most Reactions, Most Trophies
- Latest Posts, New Threads, Hottest Threads, Most Viewed Threads
- Top posters, Top reactions
- Extensible: Easy development of tab handlers for any kind of record
- Users can customize their own tabs
- You can exclude forum sections from the feed
- Display widget anywhere in the forum
- Customization of groups and tabs display
- A large number of settings for thread tabs
- Multilingual support
- Remember selected tabs
- User can hide statistics widget
- Huge number of tab options
- Purchasable Pinned Links
- Ability to add paid attributes such as color
- All links are moderated before purchase
- Purchasable Pinned Threads
Public store :
User permissions :
Member
definitionVersion 1.1.0 Patch 2 change : Added compatibility with older versions of AMS
New widget options
Fixed :
Thread type filter
Version 1.3.0 :
