Apportez des modifications supplémentaires pour afficher vos règles sur chaque forum.
En quelques étapes, vous pouvez faire ceci :
Thanks to this plugins you can:
fix
- fixed problem with edit node error
Compatibility fix
- fixed compatibility for ThemeHouse themes (UIX issue) You only need to upload files from pack.
Version 1.0.2 topic update :
- now you can show rules on every topic inside each forum
Version 1.0.3 fix :
- fixed problem with blank page
Télécharger V1.0.3 :
- set three buttons with links and own names
- set font awesome icon for each button
- set rules title for each forum
- set render image to make rules more visible
- turn on animations for buttons to make them more visible
- write your own rules for each forum usting easy HTML
- turn on/off animations, buttons, rules image
fix
Compatibility fix
Version 1.0.3 fix :
