AndyB Resave posts all 1.7
XF 2.0 / 2.1 / 2.2 AndyB Resave posts all 1.7
Titre du sujet Titre du sujet AndyB Resave posts all 1.7
Réponses Réponses 6
Affichages Affichages 313
Allows resaving all posts to fix BB code issues after an import.
If after an import from another forum software you have posts which contain raw URLs, for example YouTube URLs, this add-on will go through all your posts and add the appropriate BB codes.
.jpg
How to use :
Add 'resavepostsall' to your forum URL.
Questions and answers :
Q: Is the Last edited by notice updated ?
A: No. All Last edited by notices are removed in every post.
Q: Is the Moderator log or Admin log updated ?
A: No.
Q: Is the edit history updated ?
A: No.
Resave posts all v1.1 changes : Now preserves 'Last edited by' information.
Télécharger V1.1 :
Resave posts all v1.2 changes : Fixed issue with History link.
Télécharger V1.2 :
Resave posts all v1.3 changes : Added CLI support.
Télécharger V1.3 :
Resave posts all v1.4 changes :
- Now requires the following two Options to be disabled before the add-on can be run: Enable edit log display after and Enable edit history and prune after.
Télécharger V1.4 :
Resave posts all v1.5 changes : Now requires closing board before add-on can run.
Télécharger V1.5 :
Resave posts all v1.6 changes : Added Post ID start and Post ID end to options page.
Télécharger V1.6 :
Resave posts all v1.7 changes : Now requires running from CLI only. The closing of the board is no longer required.
Télécharger V1.7 :
Ajout de la version 1.1 :)
Ajout de la version 1.3 :)
Ajout de la version 1.4 :)
Ajout de la version 1.5 :)
Ajout de la version 1.6 :)
Ajout de la version 1.7 :)
