Updates all posts which require a post notice.
This add-on will check every post on your forum and if a domain is found which matches the options page, it will set a value in the post table so that a post notice will show when viewing a post.
(Example of options page) :
(Example of Rebuild now button) :
How to use :
1. Install the Post notice add-on.
2. Install the Post notice all add-on.
3. Enter appropriate domain into the Post notice all Options page.
4. Go to the following page:
Admin control panel -> Tools -> Rebuild caches -> Post notice all
5. Click the Rebuild now button.
Questions and answers :
Q: After running this add-on, can I uninstall it?
A: Yes.
Post notice all v1.1 changes : One of the files was named incorrectly. Now the CLI command works.
Télécharger V1.1 :
Post notice all v1.2 changes : Check Domains value in Options page and do not do any updates if empty.
Télécharger V1.2 :
How to use :
A: Yes.
Télécharger V1.1 :
Télécharger V1.2 :
